yeah they will happily make power to 9000rpm on your setup :)
Remember the dyno dymanics stuff always looks more responsive as the extra weight of the rollers adds extra load, we just spent a fair amount of time liaising with another shop and found the normal baseline run we do of 9sec from say 1500-7000 has less low end load applied. So its more equivalent to 12-13 seconds.
Jesus, might happily make power... and break a oil pump, shatter the valvetrain and snap a few rods?!?
I'll try get another run when the guys get back from the xmas break... Would doing a 1500-7800 run over 9sec be similar?!? Obviously with this turbo it wants to rev a little more :)
haha i said turbo will be happy... nothing about the engine... dont think id try either :)
1500-7800 @ 9secs (on the lowest power correction mode so it gives me conservative results SAE J1349 (2004)) is what i use to tune (after all the f3 and f2 tuning is finished) then i do a 14sec run as a heavy check @ the end. Customer never gets a 14sec printout as its unrealistic response wise.
This 9sec run gives near on identical peak rwkw to all the new Dyno Dynamics but without the inflated low and mid. The 12-14 sec run will give you the same response as the DD but about 4rwkw more peak.
WOW great results. i have also brought this turbo. Similar bolt on parts spec, just getting a few more parts together. Will be going on a Neo spec Rb25det.
Simon did you have you 6 boost made specialy? i have trial fitted my turbo using a matse 6boost but it fouled on the cam cover.
will be getting tuned on a mainline, i will post results for a comparison, but not till late jan
great work....
great work....
No I didn't have the 6boost made custom and the housing didn't foul when we put it on but when we rotated it to the desired position it did start to hit... So the angle grinder knocked a few mm off the cam cover (I'll try to remember to take some pics for you)
What fuel are you going to use?
Cool might give it a try for a comparison in the new year, cheers for the info AND the advice on the turbo!
OH ok maybe the manifolds vary a little. Or Neo head slightly different at exhaust manifold flange? wont be to hard to sort out tho
will do a tune on 98 and e85.
Went for a fairly big drive tonight...
Loading up 4th on a straight road from 3000rpm will get 1bar at 3500rpm :) It was on a boost setting of 1.45 bar and it was hitting peak a bit before 4000rpm
I'll try take some videos next time I go for a drive.
some great info here!
Keep it coming!
Oh was his E85?
I thought it was PULP.. My bad if thats the case!
nah that was pulp
on e85 he made the same power as he ran out of injector.... was only running 740's
Did some more "testing" on way to work today... Should be reasonably accurate as I have both digital and analogue tachos and boost gauges.
Loading up from 3000rpm in gears;
2nd = 1bar at 4300 (very hard to judge because it start's frying tyres)
3rd = 1bar at 3800
4th = 1bar at 3500
5th = 1bar at 3300
Edited by SimonR32
Just had a look at my turbo and it is actually the TE/TD06SH-25G Not T67 Very similar but Turbine Wheel: 58.8 / 67 mm 12 blade VS Turbine Wheel: 54 / 61 mm 11 blade, compressor is the same. Will be intersting to see the differance.
Anyone got any idea??
Simon hows the boost between gears? does it drop much? or just stays on?
Edited by DR30RSX
im tossing up to get the kando dynamics td06 25g or this t67 25g what would u guys recomend
+1 for vids:)
T67-25g
Mine is the 11 blade one which is the same as a Genuine Trust T67.
That turbine wheel size isn't really "similar" it's actually a lot bigger! If I was you I'd sell the one you have and get one like mine.
No boost drop on mine at all even when slowly changing gear to protect the box :)
Td06SH-25G in theory should spool earlier but fall over earlier in the top end due to the larger turbine.
Same front and bigger rear means it will spool slower but make a bit more top end. I think Trent wrote somewhere that the extra lag was not worth the little bit of extra power they make.
Edited by SimonR32
Yeah i was going to write some but i have no first hand experiance only what i have read.
The TD06SH should be laggier dues to the extra inertia of the wheel and the fact that the wheel is less restrictive due to (amongst other things) it's bigger exducer. The filp side to this is that it will make more power due to it being less restrictive.
From what i have read (and Trent would have more to say on this) the SL2 version of the turbine wheel used in the T67 was designed to be used with smaller capacity (i.e. SR20's etc) engines in an effort to make them more responsive but the flip side is that they will make slightly less power.
Edited by D_Stirls
Fair call on the response thing. I figured that the larger wheel and extra blade would help tesponse. But when you mentioned the extra weight and larger. Exuder it clicked that I was thinking ass about. I was taking the extra blade area into consideration only. Does anyone know of a 12 blade l2 turbine wheel size. Would make for an extra responsive 20g setup. But might involve to much f**king around. I might measure my kkk k27 turbine wheel tomorrow and compare......wow that took forever to type on my phone while drinking beer lol
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
