  • 4 weeks later...
has anyone tried the Kando Dynamic TD06L2-20g 10cm rear on an rb25 yet?
I have an adapter to run an external gate on the stock manifold and i just want to hit 280rwkw, im thinking the L2 may fall short?
They are about $800 delivered from Kando, I am itching to buy one.
To note, the T67 wheel and 10cm housing OBVIOUSLY has no power restriction (ref Simons results) and results for the td06sl2-20g can be seen on more evos than you can poke a stick at.
Evos generally do not struggle to make 260AWKW from the said turbo on a 10.5cm rear housing and are generally on full song by 4500rpm with epic spool before that also.
The fastest evo I have driven had a td06sl2-20g 10.5cm and 272 cams, it would out rev the motor and had some serious pull from about the 3000rpm range, it had made 280AWKW on that setup and featured in a magazine. Others have made over 300awkw on these turbos with E85.
Might I add we have seen Roy get 260rwkw from an RB20 of all motors on one of these turbos, with VERY acceptable spool. An RB25 would possibly spool one of these better than your average highflow.
I have a feeling that we are fools for overlooking these turbos. I really am looking at grabing one for my 1J and having an all out balistic sub 300rwkw setup. The price of my turbo, manifold and gate will rival the cost of a garrett on its own.
Sorry for the Hijack Simon, Im going to put together a thread some time with links to your own results (for ref to the T67 rear and 10cm housing) along with evo results (for ref of the T67 combined with 20g front on a itty bitty 2L) very soon.
I have ordered a t67 to go with my 6boost and 44mm tial...
Came to this decision over the td06l2 cause of posts on a
Subaru forum where the concensuss was that the L2 was too small for the 2.5l boxer engine
See how I go if it's too laggy ill just swap on a td06l2
Thread is about Kando/Kinugawa/Kamak turbos not my results, so any results you have feel free to stick them up on here :)
The TD06SL2 is the same wheel as the T67 Simon is running.
The turbo you noted prior is the exact turbine wheel and exhaust housing.
Simon has made 410rwkw with it, no restriction.
Maybe the Subaru boys were refering to a different wheel, not the SL2.
Yeah the TD06SL2 has the same exhaust wheel and housing as a T67 but with 20g compressor and housing to suit. I would still think a T67 would be better on a RB25 and the SL2 for a RB20
410kw was a little bit of a piss take with correction on... More realistically it makes 390kw on a hub dyno and 360rwkw on a dyno dynamics roller :)
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
