sigh got rolled today, went and picked up my pipework, with the bov adaptor welded in place... well wasnt that a mistake to take it to someone who i normally dont get to do my work. they totally f#$%ed the whole job. i sent an intercooler pipe with a genuine turbosmart bov adaptor to suit the stock rb25 crossover pipe, told them to cut the base plate off, or trim it up and weld it on. Now you would think, trim it up would mean keep it neat, cut it in a circle u know, using your common sense, along with drilling the hole out to suit the 32mm I/D or the adaptor, well didnt i get a shock. The welding is terrible, looks like a pile of bird shit, they didnt tidy it up by cutting the base plate into a nice circle, just lopped a bit off each end, and then to make it worse, the hole in the pipe iteslf was only 20MM seriously WTF. Luckily i have a die grinder and fixed it up, but the welding makes the whole job look like a piece of sh1t. It will get me out of trouble for the tune, but now i have 2 get it done again.
ROFL at this work from a stainless steel and aluminium fabrication shop.
Edited by OMY31T
nah $30 is all i paid em, 30 mins labour... power steering and my charcoal canister have been relocated to the firewall on the passengers side.
and all my wiring on that side is under the guard
so all i have left is
should be, but when i drive it almost everyday still.. well when its tuned i will be, you tend to get pulled over a fair bit and id like to try and avoid the EPA as much as i can hahaha.
and nah the lines run along the chassis rail then come up with the aircon pipes which they are cable tied to :D im not that silly, although i might heat shield them anyway, wouldnt hurt, im going to be doing the brake line on that side, last thing i need is boiled brake fluid, happend to my cousin in his rx7, ran a 10.4 1/4 mile and couldnt stop intime for the 1st off shoot, had 2 run all the way down to the end of the strip.
Edited by OMY31T
with that setup the carbon canister is the least of you worries... TMU will see that engine bay and then cry with tears of joy....
When is someone going to try an internally wastegated one on the factory manfiold???
Apparently the internal gate versions are average, much more cost effective and easier to use a hyper gear unit.
most of my shit is legal though defect wise, but no way in hell will i pass EPA... i have another setup for the intake pipe which will bolt up to an airbox :D, so that will make the fmic legal, the exhuast manifold as far a i know is legal as its no different to a set of extractors in theory, my wastegate i plumbed into the exhaust, my ECU is hidden, and my injectors are highflowed so they dont stand out like dogs nuts.. so apart from being unsure about the wastegate, oh and i have no boost adjuster, i dont actually know what will fail defect wise. As i said though EPA will have a field day on it.. punched out cat, one muffler, injectors, ecu... lol, no hope.
actually, hes right, after looking at it.. lol stupid me, the bov has to plumbed back to the plenum(vacuum when the throttle is shut) otherwise it wont have vacuum to open it and will stay pressurised lol, i honestly didnt even pay attention to that when i put it in last night.
Edited by OMY31T
One for Simon, how do u find the t67 vs your old t04z? I would love to know.
Kinugawa T67 on stock RB25: 1bar in 4th at 3500rpm and 480rwhp on E42.5 mix
Garrett T04Z on built RB26 with cams: 1bar in 4th 4000rpm and 575rwhp on BP98
Can't really compare them because they are on different fuels, with different motors in different cars...
They both are about as quick as each other (although the GTR would monster the Gts-t in 1st, 2nd and probably 3rd on the street because of the 4WD grip) but the Gts-t is a lot lighter so that makes up for the lack on outright power.
Really it's apples with oranges, T04Z will make 150hp more than the T67 :)
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
