I can't remember, and i am not searching but don't R34 gtr turbos have smaller exhaust housings? .64 vs .48?
theres enough info on the net with back to back BB versus journal and i've backed to backed it aswell,(BB T28 versus journal) transient response is "slighlty" better, but only really noticed on light throttle openings(1/4 throttle, bringing up a few pounds of boost ), so maybe for a motorkhana car its worth it, for the rest of us it won't make a difference
cheers
darren
they both use the .48 rear housing.
even without seeing jez's results yet, i rekon the td06sl2-20g is already a winner for a rb25 without too much lag.
if i can manage to low mount this and weld the gate straight onto the rear housing (38mm will def fit, not sure about 44mm??) then it will be something i will do.
will wait for ARTZ to see how he goes with low mounting his unit.
I'd be going the 40mm comp gate anyway 1. because it should sound better 2. because its cheaper!
trent seems to use them often with no issues.
yeah i want to cause its a very compact unit..
..but tial comes with 7 different springs TS comes with 7psi only which means I need to buy more springs :(
ill see how much i can score some for.. :)
pipe i have is 46 Outside 40 Inside.. so i measured it up..and although it looks like ti will fit from the outside but when I measured the inside of the turbo housing, because of the thickness of the walls, I think a 40mm hole is going to be the limit as the inside of the housing just wont accomodate a 44mm hole. so even if i have a 44mm gate im only going to have a 40mm pipe feeding it.
from everything i have read, it is meant to be the best place for it, run it off at an angle less than 90 degree and it should have great boost control..
TS site says to keep the gate at least 100mm away from the housing though, away from the heat as much as possible Guess i will take my chances with it under a heatshield....
**Although this setup may work on paper i really have doubts as to its sustainability if it was running hot for extended periods..**
Simon,
what BOV are you running? (If any that is)
cheers
Greddy Type R
Damn beat me to it!
http://www.skylinesaustralia.com/forums/index.php?showtopic=345095&view=findpost&p=5748802
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
