I can't remember, and i am not searching but don't R34 gtr turbos have smaller exhaust housings? .64 vs .48?
theres enough info on the net with back to back BB versus journal and i've backed to backed it aswell,(BB T28 versus journal) transient response is "slighlty" better, but only really noticed on light throttle openings(1/4 throttle, bringing up a few pounds of boost ), so maybe for a motorkhana car its worth it, for the rest of us it won't make a difference
cheers
darren
they both use the .48 rear housing.
even without seeing jez's results yet, i rekon the td06sl2-20g is already a winner for a rb25 without too much lag.
if i can manage to low mount this and weld the gate straight onto the rear housing (38mm will def fit, not sure about 44mm??) then it will be something i will do.
will wait for ARTZ to see how he goes with low mounting his unit.
I'd be going the 40mm comp gate anyway 1. because it should sound better 2. because its cheaper!
trent seems to use them often with no issues.
yeah i want to cause its a very compact unit..
..but tial comes with 7 different springs TS comes with 7psi only which means I need to buy more springs :(
ill see how much i can score some for.. :)
pipe i have is 46 Outside 40 Inside.. so i measured it up..and although it looks like ti will fit from the outside but when I measured the inside of the turbo housing, because of the thickness of the walls, I think a 40mm hole is going to be the limit as the inside of the housing just wont accomodate a 44mm hole. so even if i have a 44mm gate im only going to have a 40mm pipe feeding it.
from everything i have read, it is meant to be the best place for it, run it off at an angle less than 90 degree and it should have great boost control..
TS site says to keep the gate at least 100mm away from the housing though, away from the heat as much as possible Guess i will take my chances with it under a heatshield....
**Although this setup may work on paper i really have doubts as to its sustainability if it was running hot for extended periods..**
Simon,
what BOV are you running? (If any that is)
cheers
Greddy Type R
Damn beat me to it!
http://www.skylinesaustralia.com/forums/index.php?showtopic=345095&view=findpost&p=5748802
    • Not that I know from experience, but in theory you'd want your gate spring to be as close to target pressure as possible, so you'd go with the higher gate spring?
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
