anyone got a result for a stock rb25 with a t67 on pump? ive got a few mods like 6boost, tial gate, step 1 tomeis, 1000cc injectors, haltech.. Im really shooting for 300rwkw... achievable?
329 @ 19psi about 345 @ 21psi.
i reckon ive posted around 5 or so setups over the years. (do a quick search they may pop up)
I went to ATS in adelaide today to get some longer studs for a 10mm spacer plate. Bill said he had , had a lots of Kando dynamics
turbos in there, as S@J automotive apparently(a big subaru shop), buy a lot of them for suby upgrades. He said they where genuine
Mitsubishi internals, but they can be a bit sloppy in assembly at times, with oil seal clearances and sometimes the centre bearing oil feed holes haven't lined up with the oil feeds. Basically he said they where a great product just let down a bit with quality control and its worth getting them checked before putting them on and you should get a long life out of them
cheers
darren
Edited by jet_r31
So why is everybody being soft and using the T67 rather then TD06-25G? Cant imagine there is going to be more then 200-500rpm in it and the hotside would surely flow better and be nicer to tune. I think when the time comes im going to give the 25G a go with a 10cm housing
You mean the td06h or the td06?
IMHO the T67 hits the spot as is, id use the H on a rotor or stroker but not a pissy sub 3L motor.
haha @ soft, want a race :nyaanyaa:
From what I have seen a TD06SH-25g is a fair bit laggier with not that much more top end, so not really worth it.
But hey, maybe it's time for a T88 :pirate:
Edited by SimonR32
Ordering the t67 this week finally, I emailed him and he gave me 10% off, so i think it was $837 delivered.
Simon - my old account (cupcake) shit itself this is my new one, im keen to see my results against urs with my haltech and step 1's
i sent old mate a message regarding the td06-25g
i got this in reply, anyone go thoughts on the anit surge fronted td06-25g as opposed to the t67-25g?
Hi,
Here is the link for TD06SL2-25G turbo with 10cm turbine housing.
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-4-TD06SL2-25G-T3-V-Band-450P-/270800154553?pt=AU_Car_Parts_Accessories&hash=item3f0cf26fb9#ht_2323wt_1139
this turbo is on 5% off now and we offer extra 5% discount if you can pay through paypal to save ebay handling fee.
So total is AUD 854.03 x 0.95 + free shipping = AUD 811.3.
By the way, if you can consider another cover,
We can offer special price as we wanna clean this cover.
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Anti-Surge-TD06SL2-25G-T25-Flg-/270798756146?pt=AU_Car_Parts_Accessories&hash=item3f0cdd1932#ht_2339wt_1139
we can change the turbine housing to 10cm as above for you as well.
Total price is AUD 680 to door.
Regards
Eiji Takada
Well I have both in a box and going to give the 25G a go before T67. From the results I have seen on friends cars is the 25G catches the T67 at 4,500rpm and powers on to make 20-30rwkws more. This was from similar cars with same tuner. But was a long time ago and people are making more from setups these days so would be interesting. I will have my built motor by xmas to trial with. Will be happy with 320 from T67...they just dont seem to make power after 22psi where rhe 25G can squeeze about 24psi into them and make 350rwkws...not sure how strong my first diy engine will be and how much boost it will like
Has anyone used one of the TO4R turbos they offer?
Looking to use one these on a 4.0L xr6 engine in an r34 GTT.
Want to make a solid 450kw.
Recommendations anyone??
Not fussed about manifold I'll be fabricating my own. Prefer external gate.
And.... Now im confused on which route to take, the td06-25g with10cm and anti surge or the t67-25g..... :( help me!
Same aren't they except for comp covers?, so i guess it comes down to how much clearance you have with your manifold, if you have plenty
i'd be going the 4 inch cover, if you have a standard mani get the 3 inch.
$680 is not bad, he still want $750 delivered for that one with 10cm usually, i got him down to $720 with 2.
cheers
darren
They are not the same. Forget ported comp covers which were never offered by Greddy so I know nothing about...the T67 is smaller on the hot side.
Following are pics showing the size difference in turbines that I posted earlier in this thread
TD06L2-20G 8cm
T67-25G 10cm
and an TD06SH-25G 10cm
...have a look at the following pics to get an idea of the difference in exhaust wheel . The TD06SH turbine flows more then the TD06L2 turbine and whilst they have the same compressor, the SH wheel poses a lot less restriction.
As you can see, the SH turbine is a fair whack bigger then the L2 wheel.
I'll keep a eye out on the results... More than happy to change my turbo if something is found to be better :)
But saying that I don't really need any more power :whistling:
Edited by SimonR32
Yeh i know they are different Roy, but i think the poster was refering to the TD06 SL2 25G that kando sell,,and they are the same, the comp covers
are only different
He will do this one
http://www.ebay.com.au/itm/270794579581?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
For $664 to your door this week if you pay through paypal
I want to buy tommorrow, not sure if i should buy that one, or this one
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Anti-Surge-TD06S-25G-T3-V-Band-/290603882502?pt=AU_Car_Parts_Accessories&hash=item43a9575806
Thoughts??, i want to put it on a standard manifold. One just looks prettier from all i can tell, i don't need to turn the earth power wise, would be happy
with 320ish rwkw on a standard manifold,on pump 98 with water/meth injection hard to ignore the cheap one for the price though.
cheers
darren
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
