pretty sure they do a copy of a 3037..its 1.5k though
NO..... Damn man dont spread rubbish like that..
They sell a REAL 3037 with a Kando rear housing for 1.5k, its a great price.
sandy vag?
Thats right, i only saw it once and my memory aint so great
Though technically a 3037 should have a HKS badge on it :P
tell ya what i was thinking too scott..ya know that dud turbo on my car, why dont i put a 3037 comp wheel on it they are pretty cheap..you reckon it would fit...?
my Garrett GT3076R had a GT3037 ID ... it was on the CHRA
+1. The "37" refers to the GT37 series impeller, been rehashed and explained numerous times in various threads. Garrett make them, Garrett name them, and HKS stayed with the naming convention when being supplied those units.
I wouldn't expect to see any HKS naming on something Kando supply.
sandy vag?
LOL yeah someone else already said it, HKS box or Garrett box = same product. The HKS one says HKS on the comp cover but eh yeah... same same.
As for whacking a 3037 comp wheel on, sick idea. You will need the comp cover to match. You could send it to Stao and he would be able to fit the wheel and supply the new cover. Would need to be rebalanced.
But then youd look like a goose with a lazy 300kw when you had the opportunity to have an AWESOME!!!! 300kw lol.
Cmon man just try
yeah i am gunna do the kando dont stress..Its all set to go :thumbsup:
i was originally going to change the wheel on this one as you know but hought it would have to be balanced..i have recently been informed there is no need to balance it just bolt a new wheel in and go, a 3076 wheel is only 50 on ebay...a 3037 is 120....I could of done that..so my question was more hypertherotical ..
Yeah definitely need to balance it.
Dont forget the old T4 76mm and the GT37 76mm are different dimensions other than OD. You would need the housing too.
If I was to do it I really would just send it to HG
Hey Guys,
Been thinking about getting a TD06SL2-20G, but have come to the conclusion i prob would want more repsonse so sent Eiji an email asking if he could do a TD05-18G in t3 flange. He came back with this response.
What do you guys rekon? Would the turbo be a compromise and should i just wait for the actual T3 model to be released towards the end of November? Plus would it give me much more response over the TD06? And i assume it would have the V-band on the exhasut housing still?
Hi,
Our T3/TD05H turbine housing is not available yet until end of Nov.
I have a genuine MHI TD05H-12G turbo with 8cm housing as this listing.
http://www.ebay.com.au/itm/Turbocharger-Genuine-KUBOTA-V4702-Tractor-TD05H-12G-49178-03200-T3-8cm-New-/280763620494?pt=AU_Car_Parts_Accessories&hash=item415ed0dc8e#ht_2093wt_1185
I can upgrade it to TD05H-18G for you if you don’t wanna wait.
It will look like the below turbo.
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Cover-T3-8cm-V-Band-Housing-TD06SL2-18G-/290622631545?pt=AU_Car_Parts_Accessories&hash=item43aa756e79#ht_2686wt_1185
Unit price will be AUD 799 to door.
I could offer oil-cooled bearing housing and water-cooled bearing system as well.
If you wanna wait the 8cm/TD05H turbine housing,
Please let me know your email that I could contact? you when it is available in the future.
Regards
Eiji Takada
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
