If you look through roys build up the has the turbos side by side I'm sure the greedy version but they are very similar to the kandos you can see the size difference in the turbine wheel
Edited by Bsa
I will be getting one of but can't until I get back from Thailand in janurary as money is tight. That's why I'm researching on them as I want to get the right one the first time. Just curious at how similar the to turbos will be seen the pics side by side just wondering what would be like on power curve etc
Any body done back to back testing between the SL2 and the td06h-20g
Two near identical setups on same dyno and same tuner and no difference. the L2 was a tad worse...a tad. My car was a little more responsive and made something like 1.5rwkws more...so variable is exhaust, engine health etc. Jack difference in the turbo...and both cars were recently lapping bumper to bumper at Winton so both about the same
Kris is now running my old spare L2, making good numbers. But i didnt see anything in results that made me want to swap my H for the L2
http://www.skylinesaustralia.com/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page__st__1780
get the td06sl2 20g, it will spool faster and it can flow more than enough
also see this housing for their 8cm T3 internal gate.
http://www.ebay.com.au/itm/Kinugawa-Turbo-Turbine-Housing-TD06SL2-T67-T3-8cm-Internal-Gate-Mitsubishi-/290621301428?pt=AU_Car_Parts_Accessories&hash=item43aa6122b4
just need to have the rear lopped off and drilled out
So after an adjusment its half way there, cheers again to scottynm35 who pretty much cut it, welded it and filed it smooth in the time it took me to smoke a cigarette..:thumbsup:
I reckon I may even be able to get my stock heatsheild to cover the dumps for some extra stealthishness.. :ph34r:
also just incase anyone is interested in what comes in your Kinguwana kit, here it is,
minus the almost metre long oil line which is in my car already.
The oil drain is very small compared to stock, not exactly sure what I will do about that.. Also I was surprised there was no blank plugs in the oil and water holes on the turbo cartridge..maybe this is normal I dunno..
does anyone know what the little T-piece sitting near the copper washes is for..I assume its for a gauge sensor, but not sure how or where it would fit in with the kit :unsure:
LMAO @ TIAL stealthiness, man you crack me up. I wish we lived nearby -_-
and you can get a TFI brass fitting to put a 5/8 bung on the block from autobahn, its a 3/4 from stock i think!
Ye, has a 1/8" NPT fitting for an oil pressure gauge if you want to fir one there
Question for you, does that lip on the mounting face of the V-band flange fit into the rear housing and allow you to clamp it?
Basically I had the same flange but the rear housing was not machined to accept the lip so I had to get him to send a flat one out. A few other guys have PM'd me saying they had the same problem and had to get a replacement sent out too.
http://www.ebay.com....=item43aa6122b4
mines for a rb25 so im going to go the 10cm housing and external gate as the 8cm will choke
and artz ive also noticed your using a 10mm spacer between the turbo and manifold did you need this or did you do it just to be sure as i thought i read on here you didnt need it
Edited by luvpsi
yeah my housing is machined, fits like a glove.. guess i got lucky...
Cheers for the headsup though that could of made life hard had it not fit :cheers:
Thanks for that pic man, I'd definitely prefer to have that seal but mine seems to be sealing fine so far without it...
Scottynm35 did a great job on that housing-gate pipe!
It came up good, I wonder if you could get some sort of heatproof cover like a turbo beanie to cover the wastegate? I guess you will have a screamer plumbed over the heatsheild soon so it wont really matter, when the cops lift the bonnet you will be screwed. lol.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
