If you look through roys build up the has the turbos side by side I'm sure the greedy version but they are very similar to the kandos you can see the size difference in the turbine wheel
Edited by Bsa
I will be getting one of but can't until I get back from Thailand in janurary as money is tight. That's why I'm researching on them as I want to get the right one the first time. Just curious at how similar the to turbos will be seen the pics side by side just wondering what would be like on power curve etc
Any body done back to back testing between the SL2 and the td06h-20g
Two near identical setups on same dyno and same tuner and no difference. the L2 was a tad worse...a tad. My car was a little more responsive and made something like 1.5rwkws more...so variable is exhaust, engine health etc. Jack difference in the turbo...and both cars were recently lapping bumper to bumper at Winton so both about the same
Kris is now running my old spare L2, making good numbers. But i didnt see anything in results that made me want to swap my H for the L2
http://www.skylinesaustralia.com/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page__st__1780
get the td06sl2 20g, it will spool faster and it can flow more than enough
also see this housing for their 8cm T3 internal gate.
http://www.ebay.com.au/itm/Kinugawa-Turbo-Turbine-Housing-TD06SL2-T67-T3-8cm-Internal-Gate-Mitsubishi-/290621301428?pt=AU_Car_Parts_Accessories&hash=item43aa6122b4
just need to have the rear lopped off and drilled out
So after an adjusment its half way there, cheers again to scottynm35 who pretty much cut it, welded it and filed it smooth in the time it took me to smoke a cigarette..:thumbsup:
I reckon I may even be able to get my stock heatsheild to cover the dumps for some extra stealthishness.. :ph34r:
also just incase anyone is interested in what comes in your Kinguwana kit, here it is,
minus the almost metre long oil line which is in my car already.
The oil drain is very small compared to stock, not exactly sure what I will do about that.. Also I was surprised there was no blank plugs in the oil and water holes on the turbo cartridge..maybe this is normal I dunno..
does anyone know what the little T-piece sitting near the copper washes is for..I assume its for a gauge sensor, but not sure how or where it would fit in with the kit :unsure:
LMAO @ TIAL stealthiness, man you crack me up. I wish we lived nearby -_-
and you can get a TFI brass fitting to put a 5/8 bung on the block from autobahn, its a 3/4 from stock i think!
Ye, has a 1/8" NPT fitting for an oil pressure gauge if you want to fir one there
Question for you, does that lip on the mounting face of the V-band flange fit into the rear housing and allow you to clamp it?
Basically I had the same flange but the rear housing was not machined to accept the lip so I had to get him to send a flat one out. A few other guys have PM'd me saying they had the same problem and had to get a replacement sent out too.
http://www.ebay.com....=item43aa6122b4
mines for a rb25 so im going to go the 10cm housing and external gate as the 8cm will choke
and artz ive also noticed your using a 10mm spacer between the turbo and manifold did you need this or did you do it just to be sure as i thought i read on here you didnt need it
Edited by luvpsi
yeah my housing is machined, fits like a glove.. guess i got lucky...
Cheers for the headsup though that could of made life hard had it not fit :cheers:
Thanks for that pic man, I'd definitely prefer to have that seal but mine seems to be sealing fine so far without it...
Scottynm35 did a great job on that housing-gate pipe!
It came up good, I wonder if you could get some sort of heatproof cover like a turbo beanie to cover the wastegate? I guess you will have a screamer plumbed over the heatsheild soon so it wont really matter, when the cops lift the bonnet you will be screwed. lol.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
