If you look through roys build up the has the turbos side by side I'm sure the greedy version but they are very similar to the kandos you can see the size difference in the turbine wheel
Edited by Bsa
I will be getting one of but can't until I get back from Thailand in janurary as money is tight. That's why I'm researching on them as I want to get the right one the first time. Just curious at how similar the to turbos will be seen the pics side by side just wondering what would be like on power curve etc
Any body done back to back testing between the SL2 and the td06h-20g
Two near identical setups on same dyno and same tuner and no difference. the L2 was a tad worse...a tad. My car was a little more responsive and made something like 1.5rwkws more...so variable is exhaust, engine health etc. Jack difference in the turbo...and both cars were recently lapping bumper to bumper at Winton so both about the same
Kris is now running my old spare L2, making good numbers. But i didnt see anything in results that made me want to swap my H for the L2
http://www.skylinesaustralia.com/forums/topic/58229-top-rb20-club-do-you-have-over-260rwkw/page__st__1780
get the td06sl2 20g, it will spool faster and it can flow more than enough
also see this housing for their 8cm T3 internal gate.
http://www.ebay.com.au/itm/Kinugawa-Turbo-Turbine-Housing-TD06SL2-T67-T3-8cm-Internal-Gate-Mitsubishi-/290621301428?pt=AU_Car_Parts_Accessories&hash=item43aa6122b4
just need to have the rear lopped off and drilled out
So after an adjusment its half way there, cheers again to scottynm35 who pretty much cut it, welded it and filed it smooth in the time it took me to smoke a cigarette..:thumbsup:
I reckon I may even be able to get my stock heatsheild to cover the dumps for some extra stealthishness.. :ph34r:
also just incase anyone is interested in what comes in your Kinguwana kit, here it is,
minus the almost metre long oil line which is in my car already.
The oil drain is very small compared to stock, not exactly sure what I will do about that.. Also I was surprised there was no blank plugs in the oil and water holes on the turbo cartridge..maybe this is normal I dunno..
does anyone know what the little T-piece sitting near the copper washes is for..I assume its for a gauge sensor, but not sure how or where it would fit in with the kit :unsure:
LMAO @ TIAL stealthiness, man you crack me up. I wish we lived nearby -_-
and you can get a TFI brass fitting to put a 5/8 bung on the block from autobahn, its a 3/4 from stock i think!
Ye, has a 1/8" NPT fitting for an oil pressure gauge if you want to fir one there
Question for you, does that lip on the mounting face of the V-band flange fit into the rear housing and allow you to clamp it?
Basically I had the same flange but the rear housing was not machined to accept the lip so I had to get him to send a flat one out. A few other guys have PM'd me saying they had the same problem and had to get a replacement sent out too.
http://www.ebay.com....=item43aa6122b4
mines for a rb25 so im going to go the 10cm housing and external gate as the 8cm will choke
and artz ive also noticed your using a 10mm spacer between the turbo and manifold did you need this or did you do it just to be sure as i thought i read on here you didnt need it
Edited by luvpsi
yeah my housing is machined, fits like a glove.. guess i got lucky...
Cheers for the headsup though that could of made life hard had it not fit :cheers:
Thanks for that pic man, I'd definitely prefer to have that seal but mine seems to be sealing fine so far without it...
Scottynm35 did a great job on that housing-gate pipe!
It came up good, I wonder if you could get some sort of heatproof cover like a turbo beanie to cover the wastegate? I guess you will have a screamer plumbed over the heatsheild soon so it wont really matter, when the cops lift the bonnet you will be screwed. lol.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
