alot of plp say the cheapy ebay manifolds cause boost control issue, but lets wait and see what Jez finds out.
try changing to a stiffer wastegate spring as well.
hopefully it can crack 300 mark with E85.
dam if so, looks like it won't make near 300 on 98 :(
I was on my phone and didn't realize it it was at 12 psi
this may sound like a dumb question but how do i read that dyno chart JEZ i have only seen the dyno dynamics ones which seem easier to read i gather the very top line is boost but its still a tad confusing
Edited by luvpsi
I'll post before he does car feels wicked to drive very responsive. eBay gate is no good put my turbosmart gate on running 13 pound creeps to 15 great turbo. Jez can say the number it's just running gate pressure has a very fat torque curve kando you did it again
Edited by Bsa
No boost controller, 35mm turbosmart gate courtesy of BSA. Boost creep from 11-15 (need a 44mm gate) power and torque just kept climbing. And thats with a missfire from the coilpacks. Will get some split fires but for the time been im going to drift it on thursday before i do any more mods such as a bigger and better gate and a decent boost controller. I think with a flat 20 psi this thing will be even more insane.
I cant believe the torque didnt ever nose over,
Ok the top line is AFR
2nd line is power
3rd line is torque
4th green line is power kw
Sorry about the RPM i was revving to 7000 roughly.
EDIT: this is WITHOUT VCT. As i dont have a speed signal connected yet
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
