Scott, thanks, I do now understand the concept of an external gate setup, and hell no, I'm not going to have an open screamer and hence a massive fine and defect, it will have to plumb back onto my dump, and either collect the gases out from my stock manifold or turbo rear housing - I dunno which is easier /cheaper /more preferred..
Is it sad that I now dont want one of these turbos because everyone buying them is doing it as cheap as possible.
I am now waiting for all the threads/comments saying my car isnt performing like Simon-R32's car etc
  On 20/12/2011 at 10:59 PM, dori34 said:
modded the stock manifold to suit 44mm v-band ext gate, running either a tial mvr or turbosmart hyper gate
Did you keep the standard splitter inside the manifold when you modded it for external gate? If you didn't I would recommend that you ditch it, get a new one and weld gate to rear housing!
Guys asking about gates, I think Tial 44mm MVR off ebay for $400 is a bargain and you can't go wrong :thumbsup:
  On 21/12/2011 at 12:33 AM, GTScotT said:
Make sure you have your labour aspect of things well sorted and know the implications of a screamer (if you opt to go that way) or how standout your setup will be to NSW highway patrol.
On a dedicated street car this is why the HG wins everytime no matter the cost.
Never fear, I'll chuck some cams and springs in my car this year and try for some more power to keep the pundits happy :whistling:
Ur a pretty sad bloke Zebra, not surprising seeing as u from ACT...pinch.gif
  On 21/12/2011 at 1:20 AM, zebra said:
Will it please you if I go mount my Wastegate on my dump pipe?
oh no you didnt...
yeah MVR gate on ebay was the cheapast i saw $410 del (that seller is away till 8/1/12 btw) then next is $440 @ powertune.com.au
i got mine second hand.for $300 del.
BSA is doing the mod to the manifold for me, his pics are below of the one he did on his car and looks like the standard splitter is still in place :thumbsup:
The thing that worries me with gate on manifold is police/ pits if you get a sticker and need to go over pits to go back to standard turbo you need another manifold if it on housing pull off turbo bolt on stock turbo get a basic tune take over pits done easy as
  On 21/12/2011 at 1:29 AM, zebra said:
LOL somehow I don't think you are quite knowledgeable enough to make a comment
Since you are so clever stripey horse, I will tell you why I dont like the idea of welding onto the stock manifold - luvpsi above said it for me..
If you have fresh studs that are <10,000kms do they snap just as easily?
Reason I ask is I took my manifold and turbo off twice with the same studs and had no issues, they were all under 10,000k though. Was running 18psi on a highflow so would have gotten bloody hot as well.
Edited by Rolls
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
