Rear housing sizes, will spool up quicker but run out of puff up top.
Not having a shot. But if you dont KNOW for certain then please phrase a post so its a question.
16G, 18G, 20G are NOT rear housing sizes. They are the compressor the turbo runs. The rear housing sizes are designated in Mistu talk at 6cm, 8cm , 10cm, 12cm 16cm etc etc.
The take away is that the smaller the compressor wheel the less inertia so you are a good chance that it will spin quicker given the two turbos have the same turbine and housings. But then there is the weight, number of blades that all play a part.
Now I THINK ( :) ) the 16G would be noticable to an 18G and 20G in spool. People seem to refer to a 16G and a BIG 16G, with the Big 16G being what Trust call the 18G. (? if someone can confirm this great :) ) There is not a lot of dimensional differences between the 18G and 20G and are basically just a different trim.
I think the fact that the 18G is normally teamed with the smaller TD05H turbine and 8cm housing is the reason why it would generally be seen as the faster spooling turbo, albeit making less power as the compromise.
Wheel Sizes (Inducer/Exducer)
16G - 46.5mm / 57mm
18G - 50.5mm / 68mm
20G - 52.6mm / 68mm
So in an overly simplistic view the 16G would physically be a lot smaller and spin easier. The 18G and 20G are basically just a trim difference
16G
After reading both threads the Kandos SEEM to produce more brutal neck snapping acceleration factor on the street, less issues getting there and seem to love boost and have lot more potential in them, maybe this also has to do with the setups being external gated.. AND theyre half the price of HG turbos (kinda adds up to same with ext gate, custom dump, plumbing etc), but then later down the track u canalways swap a newer better kando turbo cos its cheap!
f**k knows how your comparing them, you must have some skills, theres not even a decent 98 octane dyno sheet in this thread, its all E85 results....
cheers
darren
Edited by jet_r31
whats the difference in the 16G 18G and 20G with these kando's. would a 16G spool faster than a 20
Those are the compressor wheel sizes. The 16g is normally also available in a big and small trim too, small trim is uncommon from kando so dont worry about it.
The big 16g shares the same outer diameter as the 18g and the 20g (68mm), you can consider them the same wheel in different trims (although they are not quite..).
The 16g will be the best spooling item and is what is used on evo's 3 - 9 (normally capable of up to 240ish all wheel kw). This is a TD05H 16g6 (big 16g)
The 18g and 20g go up in power capability from there, the truth is being a similar wheel they are probably close to as capable as eachother yet working at different boost levels. The 20g will come on a little later and a little harder but will make the highest power on the least boost.
For a fast spool application the TD05H 18g with a healthy rear housing (10cm) would be good on a 6 cylinder and should make an easy-ish 240kw
There are youtube vids of TD06 18g on 1JZ motors available, do some searching. The results are surprising, rather quick and come on very early and smooth. I would rate this to 260kw.
cheers
darren
He's a wishful thinker, thats how.
Edit...
Wheel Sizes (Inducer/Exducer : lb/min)
16G - 46.5mm / 57mm : 34 ~ 340hp (The big 16G off the EVO III is rated as 39lb/min)
18G - 50.5mm / 68mm : 42 ~ 420hp
20G - 52.6mm / 68mm : 44 ~ 440hp
16G
Here is a pic of the following wheels side by side: VF40, EVO 16G (Big 16G), 18G, and then the 20G!
cheers
darren
Ur pretty clever arent you, the dynos the only way to compare them right, smart-ass? If you were just a bit more smart then you would see in my first sentence that i mentioned 'after reading both threads..'- hence how I compared them, whether right or wrong, thats for anyone to decide and debate as thats what forums are about..seeing as dynos dont really define what it FEELS like to drive.
wait for ARTZ too, his setup is the benchmark in my eyes and i cant wait to see his results.
stock manifold, gate off the housing, good size gate, stock plenum, basic support package. :thumbsup:
Hes taking his sweet time isn't he lol...
If someone wants to lend me a Kando td06sl2-20g and will pay for a tune ill be happy to take my T67 off and give it a try in the name of science!
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
