he did get it tuned
it did something like 260kw on 17psi and he said it went like a shower of shit compared to his previous GT30 based setup. he was real happy and i last remember he was planning to retune to more boost and see over 300.
you dudes need to stop being so fanboi and actually read the damn thread lol, i have read nearly every turbo thread on this site from start to end.
DO THE SAME :domokun:
No offence intended
Ur pretty clever arent you, the dynos the only way to compare them right, smart-ass? If you were just a bit more smart then you would see in my first sentence that i mentioned 'after reading both threads..'- hence how I compared them, whether right or wrong, thats for anyone to decide and debate as thats what forums are about..seeing as dynos dont really define what it FEELS like to drive.
pretty much..unless you drove them...no point comparing what one person says something feels like lol, it all relative, you go from 200-300 it feels fast, to someone with 400
it feels slow, and so on and so on...but you knew that..do you realise the difference E85 makes to area under the curve power wise, versus 98 octane?, not just peak?
and your comparing...
lol, not long ago we needed C16 or Q16 (roo)to get those results...
Quit while you behind
cheers
darren
Edited by jet_r31
i did read thats why i said what happened to him cause he said he was gonna cmoe back after he retunes and chasing more? lol
who wants to try this?
slightly bigger then td06sl2 so will get same response, but more power and smaller then a t67-25g.
http://www.ebay.com.au/itm/Kinugawa-3-Turbocharger-TD06H-20G-T3-Flange-12cm-/290648423988?pt=AU_Car_Parts_Accessories&hash=item43abfefe34
he did get it tuned
No offence intended
that was with a lot of problems though from memory ....not really sorted out, has been a while as i remember it was the only 98 octane tuneup, unless STATUS would be kind
enough to post all the 98 octane dyno sheets he had one day, that would make the thread interesting
cheers
darren
cheers
darren
If you so insist, I got the comparison also from a couple of trusted guys who have tried both Kandos and HGs on similarly setup RB25 cars a few times, and hence also got good solid feedback on what to expect with either.. And where does the E85/ area under curve mumbo come from, are you trying to be a bigger keyboard hero by stating 'technical' stuff that even Joe Blow knows?? >_<
And where does the E85/ area under curve mumbo come from, are you trying to be a bigger keyboard hero by stating 'technical' stuff that even Joe Blow knows?? pinch.gif
E85 or ethanol based fuel like eflex have great knock resistance. This means you can pump more timing into the thing everywhere on the map, more timing down low means more torque and the graph stands up earlier.
Ethanol based fuel will make any turbo look more responsive on the dyno, you will be able to tune it harder where it counts and your area under the curve will be awesome.
Most of us that follow this thread generally have a firm understanding of what the product is and how it works, we are generally looking at the finer details to how something opperates rather than the base figures. You are getting a flaming because you are somehow interested in these turbos without a firm understanding of how the setup works nor taking them for anything but face value. Let me break it down for you:
T67 vs ATR43 G3 - Both will see over 300kw, both are proven. Both will do what a 3076 does on paper in a roundabout way. The G3 does it in the simplest way possible (cheaply bolts on), the T67 does it in a complicated labour intensive way. In the end you come out with something that is not borderlining with restrictions and sort of 'pisses it in' with the T67, and you come out again with the same thing with a G3 but it cost you a LOT less hassle.
Have you read the 10 second GTST thread? Why do you want a 10 second GTST just to run it once and daily it forever more? Because the owner just wants to know he has a 10 second GTST......... In this case us morons have a similar excuse for being involved in the developement of these turbos.
For gods sake... Hypergear has nearly perfected the art of making turbos that do spastic delivery at XYZ killawasps, why not just do him the justice of buying one. You will not know the difference, as there simply is not one for you.
Not convincing enough Scot! I think you have tried about 3 times to push me towards HG turbos, for god knows what reason I have no idea at all.. Yep i have read the 10sec GTST, HG and a good bit of the Kando thread, so guess I will stick with and follow this Kando one and see how it goes... Call it the Kinugawa Jinx..
You are very lost....
... for god knows what reason I have no idea at all..
Not taking the mickey or taking shots. But I think the answer to that question is quite clear. He feels the HG turbos are the clear choice for your desired power and bolt on requirements. Seems pretty open and shut given that the Kando internal gate turebos have a very poor internal wastegate design.
Have a look at this pic...
http://www.ebay.com.au/itm/Kinugawa-Turbo-Turbine-Housing-TE06H-TD06SH-TD06H-T3-8cm-Internal-Gate-/270877815362?pt=AU_Car_Parts_Accessories&hash=item3f11937242#ht_2092wt_1139
See inside where the dump pipe bolts to, inside you see an opening? Thats where the wastegate gases have to vent into when the IG opens. So the air has to immediately turn 90 degrees, travel 1 inch then turn another 90deg and merge with all the gases coming out of the turbine and into your dump pipe. This causes lots of back pressure and poor flow which ultimately effects how well burnt gases exit the combustion chamber and how well they make power.
Now look at this arrangment, which is more typical of IG housings
http://www.ebay.com.au/itm/Turbine-Housing-TRUSTs-T518Z-TD05H-TD05H-18G-SR20DET-8cm-/280790572009?pt=AU_Car_Parts_Accessories&hash=item41606c1be9#ht_1895wt_1270
When the IG flap opens the air is free to run into the dump pipe, be it split type or bellmouth type. The flow is travelling parallel with the turbine gases and generally offers very good performance.
That is the general thinking of why people are sayign avoid the IG Kando turbos as without even looking at dyno sheets etc you can see how compromised they are in the housings
Thanks heaps Roy, you have explained better than anyone else WHY the Kando IG turbos are not the greatest to have and why its inferior to typ IG setups, I have been all set to go an EG Kando setup from sometime back, and then yesterday some guy goes that hes goin to try the IG Kando setup and Im like I will wait to see if its good, then I will follow, but after your really good explanation above, I will stick to my EG Kando prospect...kudos!!
ive got myself a pair of these td06sl2-25g with 4in compressor covers these are rated for alot more hp with the 25g wheels and the bigger covers so im hoping these will get me over 500rwkw's on my 2j............opinions?
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-4-TD06SL2-25G-T3-V-Band-450P-/280793716907?pt=AU_Car_Parts_Accessories&hash=item41609c18ab
and eiji has put these rear housings on it for us instead of the 10cm jobs make it more streetable........i think with 10cm rears would make it a lag monster
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-TD06SL2-20G-T67-25G-T3-8cm-AR61-V-Band-External-/280795689988?pt=AU_Car_Parts_Accessories&hash=item4160ba3404
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
