If somebody really wants to try this, the thing to do is email a request for a: TD06SL2-20g T3 10cm Internal wastegate with rear housing opened for use with 5 bolt or individual dump pipe, not single 3 bolt outlet and covered wastegate. wastegate to be uncovered.
What's wrong with a 3 bolt flange?
Sorry if something similar has been answered...
but im in the market for a turbo, want straight bolt onto rb25, and responsive 230-240rwkw
noticed they have a range of bolt on turbos for a 25, just not sure which one.
thanks in advance!
theres nothing wrong with a "three bolt flange" in general, but these particular internal gate turbos that have a 3 bolt flange only have a little 2.25" outlet (from memory) and the rest of the flowpath is blocked off.
Understand what I mean now? Im simply identifying the cruddy IW housings as a 3 bolt
thanks in advance!
Did u post this on ns.com, If so I replied there
thanks in advance!
i think this is your answer - http://www.digi-hardware.com/rb25t3hiflow.html
$960 (inc stainless oil lines) + postage. you cant really beat that.
be good to see someone give one of these kd gt3582's a go
http://www.ebay.com....=item416003bba9
That looks epic, I would totally want one of those. GCG do a 3566R which is pretty much the same thing, they do it for XR6Ts. I rekon that would be a cool turbo, worth a shot. Price is phenomenal too.
Guys, Eiji has told me they only have surge slot front covers ATM in sl2-20g. Any difference with these compared to non surge slot? Would it affect anything if I run this cover??
Shouldnt be an issue. AFAIK Minor edge taken off the spool is the only ownside, might not buck as hard onto boost.
3540/66's have been built by everyone since the dawn of time, fastest vl has run 9.2 at 147mph in a full weight calais on 38psi with one , mid's 9's is typical
Would be awesome for a cheap 3.0+ turbo, or 2 on a 5.0-6.0 V8....
They take a fair edge of spool with that big comp wheel aswell, its a fair bit of a mismatch.
Be interesting to see how the twin entry housing went with a 6 boost
cheers
darren
Edited by jet_r31
Oh yeh forget to add a few weeks ago, Willal racing used to, and still does on there street gtr i think, run twin TD06 25G's on the os giken 3 litre motors, think they made'upwards of
650rwkw, the car went 8's at 160ish mph in the end, i remember the street car made 470rwkw on 20psi on bp ultimate 98 back in the day and ran
high 9's at 144mph in street trim, i think its on E85 now with a lot more power
street car
Edited by jet_r31
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
