Sweet cheers for the reply. Now to find out if there is any advantage to the other options. I think the billet compressor wheel is a deffinite must have for the Rb30 too.
f**k knows on the billet part, if its the same comp wheel just machined out of billet....no difference, if its a slightly different design that flows more LB's, then worth it...
cheers
darren
Here is the 3037s graph showing torque and power. The pink run was the original turbo, the red one was after it was rebuilt by GCG.
Look for a faint pencil line, that is SimonR32's run on E85. It shows T67 a little behind the 3037 until 4500- there's nothing in it so you can say they are roughly the same- after which, the T67 walks away.
Both my runs are at 19psi
I know i said mine made 430, it did, this was re-tuned after i plumbed the external gate back into the main exhaust which lost some power in the top end - not shown in these graphs.
Here is the power/torque graph i tried to post a few days ago. Hopefully this is clearer/bigger, I've included the link this time as well.
http://i51.photobucket.com/albums/f377/jungle71/photo.jpg
Another hybrid
http://www.ebay.com....=item3f11ac8b09
And seeing as they sell the Gt3540 comp covers
http://www.ebay.com.au/itm/Turbo-Compressor-Housing-Wheel-Kit-4-Garrett-T04S-AR70-GT3582-/290653484892?pt=AU_Car_Parts_Accessories&hash=item43ac4c375c
Why doesn't someone ask him to measure them, and the 4 inch T67 cover for overall size and then you will have you diameter answer as
we know the garret cover fits on standard manifold with a 14mm spacer
cheers
darren
Edited by jet_r31
i be looking at a holset hx35 or hx40 for a rotor can pick them up for under $750 brand new.................ive used one on a vn commy was a bloody good turbo good for 30psi no problems..........few guys are running them on 2j's getting good results
or check out the kando t04r range of turbo's..........i be running a a/r 1.00 min for a 13b
http://www.ebay.com....=item43abdbaba8
or a turbonetics hurricane for $950
http://www.ebay.com....=item2c60c9f47d
I actually missed that 66- P trim 1.00, that might work quite well if you don;t mind some lag on a rotary, and easy to upgrade housings, might get my mate to try one on his
cheers
darren
Are peopld calling the plain TD06 the "h" variant? If so what are they calling the SH wheel? I find the Trust speak easier to follow. When my TD05 arrives I will take photos of them all side by side and you will see the clear differencbetween TD06/L2 and the SH
Hi roy,
I don't think so, Well I know I aint any way. The pics would be great.
by td06h he is referring to a SH 67mm, if that helps.
I suspected he was. I have never seen a SH-20G. Looking at a L2 vs SH, I would be shocked if it spooled the same.
the td06h is more for top end really
Yep, tend to agree.
Keen on trying the td06h hopefully isn't all that more laggy then t67
If you mean SH vs L2 off the T67 then I can tell you the TD06SH-25G makes about 20rwkws more but is a little less responsive. Look at the below pics of the differences in turbines and you can see why. Back in the day a mate had and a circle of people around him all went Trust crazy and that's part of the reason I ended up with a 20G. The TD06SH was down on power vs the T67 up to around 4,500rpm then it out grunted it all the way to the rev limit.
I had one on my 20 would be wicked on a 25 I had full boost by 4200
Reading the posts above on this page I think some of the above posts seem to suggest an SH makes ~18psi by 4,200rpm on an RB20.; which happens to be when I make about 20psi on my TD06. I think you will find if you ran an SH wheel you would be making boost about 500rpm later, similar to if you ran a 10cm housing rather than 8cm
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
