Car isnt even in the same state as me at present. All is ready to go, just need to get my car back as its currently getting some fabrication work done. I hope its going to be a bit of a weapon at Sandown in late April. Will be on E85 with the whatever proves the best performer. If its the billet then hopefully makes power at 26-28psi. On EVOs they seem to love the higher pressure ratios so the lil 20 will be earning her keep. Would be nice to make 320rwkws with the 73HTA or 250-260rwkws with the 18G
Well, I suppose I have Datalogit so will just buy 200L drums of E85 and run straight E85 at the circuit and throw 98 tune back in for getting around town. Pain in the ass, but everyone else is doing it so the lap times don't stack up without it :( The cars running it just have so much extra grunt for free, its not a level playing field running a full weight RB20 on 98 :(
Nobody has said anything here but United have 100 back. My car makes an easy 10-15rwkws more with it so tempted to run a 50:50 with 100 United / E85 to try and get some mileage out of the 200L of E85.
Kind of relevant to this thread...
This guy is using 2 x td06SL2 20Gs on his engine..
if you are interested....
it is a 1GZ-FE - 5L V12
Auto box
In to Gen 3 Subaru Liberty converted to RWD.
Build thread here..
http://www.performanceforums.com/forums/showthread.php?67274376-Cracka-s-white-boy-shitbox-Gen-3-Liberty.-TT-V6-wouldn-t-fit-so-now-V12.
First start up vids on page 19 (not all hooked up yet but still...)
enjoy.
Mick_O is getting remarkably good mileage out of E85.
I drive 320kms to / from site every week + daily drive of about 30kms. I dont want to be paying for E85 and trying to source it. Hell, I may go a 91 tune :)
And replace your blocked injectors every 10,000ks lol
Honestly most family of mine who do not listen to me about the perils of 91 end up coming to me asking why their car runs like a lawn mower. Its ALWAYS a blocked injector, no matter how new the car is.
Just sayin' :whistling:
Have been running the EL wagon on 91 for about 8 years now. Never had a problem with blocked injectors.
My economy on E85 is pretty close to what it used to be on 98 as i only go for a blast here and there in my car as its not a daily driver.. Last tank of juice i got 410km with the fuel light on at 400km. Was spewing last week though E85 was $1.33 a litre most ive ever paid!
Yeah, TBH ive never had a problem with 91 in a falcodore.
91s hit list has been mostly nissan, toyota and honda. Pulsars, Corollas, Tidas, Echos, Celicas, Civics, that sort of thing and yes I have fixed a lot of bad injectors as a result of 91.
Either way I classify 91 as piss and think anyone would have to be stupid to use it in anything. Your call.
yeah i noticed the united 100, but i tuned with bp98 as usual i think, actually I dunno cause the fuel had been in the tank for 3 or 4 months before the tune so whatever I filled up with last, might have been caltex :unsure:
And people say fuel goes off...:no: so the united 100 is good yeah..?
Yeh, my tunes are not that line ball so when United have 100 I go to my 100 tune and just run 98 on the street. But when I go to the track I make sure I am running 100. Keep in mind 8 out of 10 drives I dont hit more then 4-6psi as I drive to attract as little attention as possible :whistling:
^ thats awesome mate thanks for sharing, helps me decide if i want one on my SR :)
Can you divulge the specs of that motor? Is it heavily moded or internally stock etc? headwork and cams? Thanks,
Also great to hear your getting back on the dyno today dori! cant wait
SR is forged with 260 pro cams with solid lifters. But tiny front housing is restricting power.
gday guys, thought id post my results from using one of these turbos
i have a tdo06 20g sl2 8cm rear on my rb20
turbosmart 40mm wastegate
550cc denso injectors
bosch 040 fuel pump
z32 afm
splitfire coilpacks
ebay spec front mount
3inch exhaust
Nisstune
still needs a little tweeking like a new CAS, decent front mount and cam gears are on there way.
cheers - trent
How much boost pressure? Looks like around 1bar from the figure. The cas holding you back? And what exhaust manifold?
Just trying to gauge if one of these is a compariable replacement to the trust item.
Cheers.
Cheers. Engine bay needs work as I have never cleaned it up properly after the fire. Plus loads of other small jobs where I just dont have the time as I am always away with work. Like ripping the dash apart on the drive up to Sydney over Xmas because my phone charger stopped working. So I cracked the shits and ripped out the centre console :closedeyes: Farking old cars...if you try to keep them tidy it never ends :nyaanyaa:
Im not sure about that, i think its the same as their 3" cover but with a 2.4" neck.
Thanks for sharing btw :)
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
