he isnt a large mainstream tuner like ADVAN/CRD etc
but probems were out of his control unfortunately.
i did ask jez to finish off the tune but he couldn't do it for the price my tuner quoted to finish (but ended up getting a discount after his stuff up initially)
he reckons 270rwkw~ as i said i wanted 280+ but he is doubtful.
and he says his dyno is low reading one, we'll see when i visit Jez and run it on his dyno to see the differences.
Correct. U paid for 90% of the tune already. So best for u to pay 10% to finish off the tune then another tune with me.
I would have loved to tune ur car. But i didnt want u to spend more money than u already have
U tuning with Unique Autosports in Seven Hills? They do a lot of 300ZX TTs - wonder why those fairlady Zs are so underrated - apart from a difficult engine to work on and overheating issues, they are a stronger base and in the 2JZ category I would say.
They don't overheat when taken care of lol.
Another highly underrated power monster i would place in the same category would be the Mitsubishi 3000GT or GTO...
^^ they are buckets honestly gearbox made of butter.... poor handling and hell heavy.
Cheers. Engine bay needs work as I have never cleaned it up properly after the fire. Plus loads of other small jobs where I just dont have the time as I am always away with work. Like ripping the dash apart on the drive up to Sydney over Xmas because my phone charger stopped working. So I cracked the shits and ripped out the centre console :closedeyes: Farking old cars...if you try to keep them tidy it never ends :nyaanyaa:
internal road rage.
Im trying to get my head around the million different turbo's these guys offer, also im still deciding whether to go high mount or use the stock manifold. What im after is a responsive street car with a power goal of 270rwkw.
Low mount choice, Do i go a a TD06H-20G in a IW with 12cm rear or TD06H (also 12c) with the Garret 60-1 Comp? Also IW?
Will the 12cm rear be to laggy?
High mount options i was looking at, TD06L2-20G 10cm or the T67-25G 10cm rear?
Im not fussed high or low mount, just want the best response, while reaching my power goal.
Cheer's!
Cheer's!
Hey mate, it definitely is a looonngggg thread with lots and lots of info, yet everything you want to know has been covered many times over.
Just to recap for you: we are only considering the TD06L2-20G 10cm or the T67-25G 10cm on an RB25 in all scenarios. The IW housings are a crap and arent stacking up even when trying to improve them.
You will need to run an external gate on an RB sized turbo, we recommend the tial 44mm gate as per SimonR32. If you are running a 4 banger you can go to the TD05H-18G in the SR20 spec housings, these do work and net around the 240kw mark.
For your goal of a zippy 270kw you should be looking at the TD06L2-20G 10cm with a small spacer and hung off the standard manifold. I recommend you hang the gate off the rear housing.
Alternatively, Hypergear has an excellent internal gate option called the SS1PU. It does not have the same 'scope' as the 20g (20g looks like it could be stretched to 300kw) but it does have the ZIP you are after.
Please have a read of this thread start to end, you will understand more than what you need to know to make an informed decision.
GTSCott, yeah thats him.
hes more known for his work on 1jz/2jz's.
so yet again, more problems...
his laptop fked up, he got a new one and it isn't compatible (or doesn't sync) to my haltech.
I would of thought haltach is compatible with windows xp/vista/7 but he says it won't sync, i just hope it isn't related to my ECU.
not very happy about this as it is all his fault. if only he tuned it properly from the beginning and is now causing a big inconvenience to me. so much for having it for 2 days only, except he rings me on Thursday saying his laptop failed, when i dropped it off on Tuesday. Just shows nothing was done until the Thursday.
nothing i can do now except wait...........
Mate, just ditch that incompetent tuner.. One problem after another. Time to move on. :action-smiley-069:
I'd get him to invoice for his time to date and move on. Doesn't sound like fun, id totally be pissed.
Then you can get son of rajab DVS JEZ to tune your Kando the great, and everyone's happy.
IMHO he owes you a refund. You have paid for more than you received and you cant have the car off the road forever waiting for him to resolve his own issues.
As much as its an unfortunate situation he should be willing to invoice for what he HAS done (not 90%) and refund the remainder.
If not 'do ma con cac i kill u' and see what he says then.
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
