See if he offers money back gaurentee's?
I do. If some one isnt satisfied i will refund all tuning money and load the tune back in they came with. Hopefully it never happens.
I will try help u out as much as i can for price wise buddy.
Let me know.
Yeah, i will speak to him if there is any further delays and ask for money back, and he will reload the old tune and ill just drop it off @ jez's
lolololol
Still battling with the tune >_< Sounds like JEZ is the way to go here... Hopefully your tuner can be reasonable after everything you have been through :glare:
How come? You wanna go for a schpinn?
You can call ARTZ, his is running and making an awesome 267kw at only 1 bar and with a failed clutch :)
pretty sure he was referring to Jez so he can use him for tuning lol
I know, and i hope so too!
JEM was on the cards early last year but he couldn't squeeze me in.
hopefully can get it sorted out asap. i miss my car :(
Sorry that was directed at JEZ, people got their posts in before mine. I probably would have gotten JEZ to tune my SS1PU if he were in Melbourne, but my car is in very good hands at Racepace so :)
As for Artz, I plan on dragging the mofo if my SS1PU does what it's supposed to ;)
JEM are the gurus when it comes to Haltech :thumbsup: I cant wait to get my car tuned.... I MISS my car after 2 years lol
Look forward to seeing the finished result on your beast :cheers:
New haltech and vipec/link software is awesome and very similar. Same layout which makes things easier.
Race wars
Kando vs Hypergear.
Gonna be a good race. I wanna see results for a rolling 3rd
Gear start from 2000rpm. Or 4th if ur on a race track. Curious to see who comes on boost 1st an wins up top
Haha Im getting more keen on the Kando vs Hypergear result than Dori's results lol..
Don't forget, the abilities of the drivers count big time as well.. So maybe do a driver swap and see if the results can be replicated..?
How can the driver abilities count? Goes like this-
Pull up at lights look at each other,
Kando driver says, "whts the retail on one of those",
"More than u can afford Pal, hypergear" rev car and make dose.
Then cruise up to race track Put in 4th gear both at same speed around 2000rpm. Look at each other, nod then foot flat
How can the driver abilities count? cruise up to race track Put in 4th gear both at same speed around 2000rpm. Look at each other, nod then foot flat
:pwned::rofl2:
I'll take a stab in the dark that, in a rolling scenario from low rpm (2000) my car should pull ahead, given it's the more "streetable" turbo and gets on boost from about 3000 onwards...until around 4000, where Artz would come on and start to reel me in / eventually overtake. From there who knows...probably come down to max power and turbo efficiency in the top end. The Kando might well take it there if Artz can get his slipping clutch sorted.
Would be interesting to test a couple of different scenarios...the rolling from 2000rpm to test lag, and a rolling from 4000rpm where both turbos should be well on song, to test their response (?).
We can swap cars just to get a feel for each turbo, compare based on subjective opinion...but the only fair objective competition would be a rolling drag IMO, taking driver skill out of it.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
