Rpm is a roller speed ratio that i have to input rpm It matches the log from the Nistune. When i get back to the shop i will take a pic with roadspeed
Why do u ask?
I just prefer road speed. Some prefer rpm but i look at road speed as i takes into account diff and tyres so better real world result in my eyes
And those saying go 10cm on a 2L i think you may make a peak number easier, it may even be a few kws higher; but the net result is terrible vs an 8cm on a 2l. Sure the RB20 is different to an SR20 but the result will be the same....no mid range and about the.same top end. If you are worried about.combustion effeciency and back pressure but in a slightly bigger.turbine or better flowing turbine in the same housing size. Seems that will give a better ovrrall result then putting too big a housing on a 2L
Thank you.
Roy i will get it for u this arvo.
Thanks guys. Since I know have the 8cm we will give it a go and change to the 10cm if needed. Id like to keep the boost to a max of 20psi.
Scotty I'll be running a tial 38mm gate, unless I should go the 44mm? Havent bought one as yet. A mate Rex Kelway is making the high mount T3 external manifold for me in the next couple weeks.
Edited by slippylotion
stick with the 8cm like roy and i mentioned. Roy's explanantion is on the money.
Go the Tial 44mm, safe option and proven to work with the combo!
Ive thought a lot about getting a Kando with the T2 housing and hanging it off the housing. Could potentially work really well.
http://www.ebay.com.au/itm/Turbine-Housing-T67-25G-TD06SL2-20G-T25-Inlet-8cm-/290698119395?pt=AU_Car_Parts_Accessories&hash=item43aef548e3
I just prefer to go bigger, housing and gate. Less restriction is always better but there is of course that lag penalty. I have never driven a 300kw 2L but I can imagine it would come on late.
Split it and buy a 40mm Vband gate, realistically they should all work fine.
It was making 270rwkw on 18psi on the old turbo set up. Full boost at 3800 and peak power at 7700rpm. Drives very nicely for a 4 banger, plenty of torque. Positive pressure from just under 2000rpm.
Ill give the 8cm a crack and maybe grab a 44 mm tial if I find one at a good price. Was thinking about a turbo smart 40 but they seem to be a heap dearer than a tial gate.
Thats helps loads. Thanks. I am assuiming ts on 98? Is VCT on? A friend wants my TD06-20G when i take it off in a few weeks and trying to find some results to show him to give him a reliable feel for what he will be able to get out of it
Yes this has VTC on and is tuned on 98 octane fuel.
So I was on ebay and had a weak moment...
...Poncams should arrive later this week :)
Glad i am not the only one that did that :P
But the price!!! So cheap!!! Hard to say no.......
256/8.5mm or 260/9.15mm???
This will be real interesting. Just remind me, do you currently have cam gears? Do a run before the cams go in and tune to get the latest and greatest run for reference. Or not....if its going to cost dollars or agro
Would be awesome to see the before and after difference... I've been searching and there is no real back to back comparisons i can find.....
I think the Type B 260's are the best for a Kando yeah? (I am only learning as i go and from what i have read they are best for Mid-large turbos??)
R33 RB25 only come in 256 8.5mm, I think you will find the 260 9.15mm are for the NEO solid lifter head.
I currently have an exhaust cam gear retarded 4deg, I'm under the assumption that with poncams 0 on both sides is the best so will most likely set and forget.
We have the before runs because nothing has really changed since the last tune, unfortunately it wont be a direct comparison because I'm also going from Nistune to Vipec (AFM to MAP) at the same time.
Hoping for a extra power everywhere above 4000rpm and maybe a tad extra down low :)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
