Got mine tuned today. 380rwhp @ 17psi. We had problems all over the place getting it running, once those were sorted then had issues with trying to tune it with the ECU not playing the game with the TPS. The guys did an awesome job in the end and we called it a day as just run out of time.
So thats the T67 with antisurge, NZ manifold, Tial 44mm MVR, Stock inlet manifold/TB and 98 oct.
Will post a sheet when i get it, was in a rush to get home so forgot it. Haven't driven it yet, just got home as i live 3hrs from the tuners and she's still on the trailer.
thats good to hear the anti-surge worked for you, it was most probably just my car didn't like the Anti-Surge cover for some weird reason.
I know a few evo's & sti's run the anti-surge cover without any hiccups as well.
Did you try a higher boost setting or didn't have time to go past 17?
Yeah just run out of time, held the poor tuner back late as it was :(
It seems to have, still yet to drive it to gauge response etc.
hahhaha yeah I ment the Patrol, I wasn't paying attention when I left my work at the other end of the street and nearly drove into it lol. I'm real bright some arvo's hahahah
Dont worry, when ive finished a night shift and i drive the 5k's home i could easily run into something then just fall asleep.
Was yours a T67 as well?
Took it for a quick spin yesterday, has some oil leaks from the oil cooler blocks. Pretty laggy, gate doesn't open till over 4k, then just pulls hard to the limiter if ur not quick, the sound so far is cool, I think because it's laggy it won't horn me for a while. When it goes back for more fine tuning we'll see if we can get it on earlier.
so after a few hours of reading and not finding the answers i was after,does anyone have results of the tdo6 20g sl2 on a rb25 with external gate low mount on pump gas?i would love to see sum dyno results if possible.cheers
no worrys jez will do.its definatly the way im gunna go just seems to be alot of talk about the t67 and how well it performs.i might need to do sum more reading to find sum more info on the td06. :unsure:
231 pages...so much crap talk in the thread yes, but guessing the question has been asked and answered every 5 pages means its been asked and answered over 50 times. ie, Kando dont do any such turbo. Go look at high flows from whoever you fancy for hiflows
What kando turbo can people reccomend for my r33. Im after an intenally gated with 6 bolt dump to chase around 250ish rwkw.
Also prices would be handy. Thanks
kando need aftermarket manifold, external gate, dump pipe and etc. For bolton turbos look into hypergear's turbo thread.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
