Got mine tuned today. 380rwhp @ 17psi. We had problems all over the place getting it running, once those were sorted then had issues with trying to tune it with the ECU not playing the game with the TPS. The guys did an awesome job in the end and we called it a day as just run out of time.
So thats the T67 with antisurge, NZ manifold, Tial 44mm MVR, Stock inlet manifold/TB and 98 oct.
Will post a sheet when i get it, was in a rush to get home so forgot it. Haven't driven it yet, just got home as i live 3hrs from the tuners and she's still on the trailer.
thats good to hear the anti-surge worked for you, it was most probably just my car didn't like the Anti-Surge cover for some weird reason.
I know a few evo's & sti's run the anti-surge cover without any hiccups as well.
Did you try a higher boost setting or didn't have time to go past 17?
Yeah just run out of time, held the poor tuner back late as it was :(
It seems to have, still yet to drive it to gauge response etc.
hahhaha yeah I ment the Patrol, I wasn't paying attention when I left my work at the other end of the street and nearly drove into it lol. I'm real bright some arvo's hahahah
Dont worry, when ive finished a night shift and i drive the 5k's home i could easily run into something then just fall asleep.
Was yours a T67 as well?
Took it for a quick spin yesterday, has some oil leaks from the oil cooler blocks. Pretty laggy, gate doesn't open till over 4k, then just pulls hard to the limiter if ur not quick, the sound so far is cool, I think because it's laggy it won't horn me for a while. When it goes back for more fine tuning we'll see if we can get it on earlier.
so after a few hours of reading and not finding the answers i was after,does anyone have results of the tdo6 20g sl2 on a rb25 with external gate low mount on pump gas?i would love to see sum dyno results if possible.cheers
no worrys jez will do.its definatly the way im gunna go just seems to be alot of talk about the t67 and how well it performs.i might need to do sum more reading to find sum more info on the td06. :unsure:
231 pages...so much crap talk in the thread yes, but guessing the question has been asked and answered every 5 pages means its been asked and answered over 50 times. ie, Kando dont do any such turbo. Go look at high flows from whoever you fancy for hiflows
What kando turbo can people reccomend for my r33. Im after an intenally gated with 6 bolt dump to chase around 250ish rwkw.
Also prices would be handy. Thanks
kando need aftermarket manifold, external gate, dump pipe and etc. For bolton turbos look into hypergear's turbo thread.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
