Got mine tuned today. 380rwhp @ 17psi. We had problems all over the place getting it running, once those were sorted then had issues with trying to tune it with the ECU not playing the game with the TPS. The guys did an awesome job in the end and we called it a day as just run out of time.
So thats the T67 with antisurge, NZ manifold, Tial 44mm MVR, Stock inlet manifold/TB and 98 oct.
Will post a sheet when i get it, was in a rush to get home so forgot it. Haven't driven it yet, just got home as i live 3hrs from the tuners and she's still on the trailer.
thats good to hear the anti-surge worked for you, it was most probably just my car didn't like the Anti-Surge cover for some weird reason.
I know a few evo's & sti's run the anti-surge cover without any hiccups as well.
Did you try a higher boost setting or didn't have time to go past 17?
Yeah just run out of time, held the poor tuner back late as it was :(
It seems to have, still yet to drive it to gauge response etc.
hahhaha yeah I ment the Patrol, I wasn't paying attention when I left my work at the other end of the street and nearly drove into it lol. I'm real bright some arvo's hahahah
Dont worry, when ive finished a night shift and i drive the 5k's home i could easily run into something then just fall asleep.
Was yours a T67 as well?
Took it for a quick spin yesterday, has some oil leaks from the oil cooler blocks. Pretty laggy, gate doesn't open till over 4k, then just pulls hard to the limiter if ur not quick, the sound so far is cool, I think because it's laggy it won't horn me for a while. When it goes back for more fine tuning we'll see if we can get it on earlier.
so after a few hours of reading and not finding the answers i was after,does anyone have results of the tdo6 20g sl2 on a rb25 with external gate low mount on pump gas?i would love to see sum dyno results if possible.cheers
no worrys jez will do.its definatly the way im gunna go just seems to be alot of talk about the t67 and how well it performs.i might need to do sum more reading to find sum more info on the td06. :unsure:
231 pages...so much crap talk in the thread yes, but guessing the question has been asked and answered every 5 pages means its been asked and answered over 50 times. ie, Kando dont do any such turbo. Go look at high flows from whoever you fancy for hiflows
What kando turbo can people reccomend for my r33. Im after an intenally gated with 6 bolt dump to chase around 250ish rwkw.
Also prices would be handy. Thanks
kando need aftermarket manifold, external gate, dump pipe and etc. For bolton turbos look into hypergear's turbo thread.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
