Nice. After my playing with turbos I was just going to go with my one but went T67 just so I could baseline my results against others as I am still not sure about the performance of my new kinder surprise engine. I have said this before but this time will follow through. Need to get my car over to you for a few runs so I can understand whether its far off what a T67 setup can do,
I am making 325rwklws at 18psi falling to 16psi from about 5,500rpm onwards. After PI am going to make a few changes then will give it a few runs. Feels pretty healthy at 16psi and will be pretty easy on the engien and the track...also a little easier on the RB20 box
its all good, i know what its like, i have a similar list of things i never get done :P just let me know in advance and we will do whatever we can to help out.
That isn't flash! What setup, assuming stock SR20 with bolton internal unit? How much boost, was that maxed out? Looking at one for that kind of setup....
Sent from my GT-I9505 using Tapatalk 2
STD 1988 laurel RB20 @ 19psi wont make anymore no matter what @ 19psi... @ 23psi today it made 245kw but id prefer to leave it at 19 psi... was hoping for 250 @ 19psi but impossible. the HKS GT2535 had alot more topend... but laggier.
dont get me wrong area under the curve is great and it drives well, but car has full comp grip setup and 230-240kw is struggle town on new semis at drift days.
Ok so i just had my rb20 tuned with adjustable cam gears td05 18g. He is saying that the boost is spiking to 22 psi and then dropping to 18psi. I was wondering if its the gate that could be doing this. Its just making 190kw and thats just not enough for me.
I do have a cheaper vband gate on there swapping it to a turbosmart.
I have 750cc e85 injectors bad idea if i just go e85
Can anyone help
I've done a TD05-18G on an SR from Kando, which works well. Has done a couple of tens of thousand K's since install and countless beatings.
Holds 16psi well with a minor tapper.
The TD05H-18G gives reasonable down low with a sudden surge onto good power at the 3700 mark. Motor is an SRDE non VCT. VCT models would do better in terms of spool character.
Back to this - after much umming and ahhing the PE1420 from a certain S14 is going to be replaced with a Kando TD05-16G, T25 internally gated with the 3" intake housing and will fabricate to suit. Will be interesting to see how that performs :)
A birdy told me that one of our SAU commoners saw 300+ at the hubs from his stock E9 turbo on 25psi (TD05HR-16G6 for those unawares).
I am also in talks with Stao to consider a high flow small inducer turbo for my own SR, the thought itself came from the 16G6 wheel which is a 50 trim 68mm wheel :) Thus I will be very keen to see your said 16G6 results also. Don't be shy with the boost though! It should be great.
  • Like 1
I know people who have done ~300kw @ hubs from stock EVO 9 turbos as well, as well as EVO3 16Gs with the bigger comp and turbine housings. We are going the non-EVO fit EVO3 spec 16G with 8cm housing so I'm picking we'll be able to make some decent power. The car only has a 2.5bar sensor so we can't get too carried away with boost, but I am sure we'll still get OK results :)
Sounds mickey mouse. On E85 the sensor shouldn't hold you back too much, safety margins will be in place from the fuel alone to let you push beyond the absolute MAP reading.
Looking forward to seeing what its got. Hopefully big spool and 300+ at the hubs.
Its a stock engine, with a stock gearbox, and a track car which had more power than braking/traction last time it was out so pushing the turbo to it's limit right at the start (we've already maxed out and popped a PE1420 lol) is not the highest priority :P It will make more than enough power on 18-20psi at this stage. When the VE head goes on things will get more interesting ;)
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
