sorry dale I don't like to post dyno graphs, as my tuner ramps the car up different to avoid horrible wheel spin and the graph seems laggy if that makes any sense 2 you? so dnt want to start a shit fight.
but on the road it comes on a lot sooner then what the graph shows.
and old tune was actually 442 at 22psi. now 485 at 22 lost around 30hp in mid at 4500rpm but obviousily gained 40hp up top. pickup car this morning so see how it drives soon.
peak power went from 6600rpm to 7200rpm
Edited by methz
hey i've had a search of this thread and googled but didn't find what I'm after, most of it seemed to be about the rb20.
I have an r33, daily driver auto on stock ecu and stock engine, and it's staying that way, although an safc neo ready to touch up the tune a little once the turbo side sorted. Usual 3in exhaust, hiflow cat, fmic, metal intake mods. I've been looking at the TD05 18g with 10cm housing and antisurge cover here
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-Bolt-On-3-Anti-Surge-RB20DET-RB25DET-TD06H-25G-T3-10cm-/281245773483?pt=AU_Car_Parts_Accessories&hash=item417b8deeab
what are people's thoughts on this on the rb25 and running around 13-14 psi? Like I say not looking to change engine or ecu or run any high boost so don't need anything that will flow more than what I need, really after response (esp being an auto) and a turbo the 'right' size rather than room to make more power I'll never end up using.
I notice it's also about $70 cheaper from the kinugawa website rather than ebay, is that a marketing thing, or any catch there?
also the bullet-nuts they sell, while prob not a big difference it does look like it would be better aerodynamically (and they look sweeeet)....people's thoughts on those, and use aluminium or steel?
I really don't know too much about these so very keen on people's opinions and experiences. Thanks!
More the fact that the airflow characteristics - mass throughput - will likely be very different to what the OEM turbo does. So fuelling and ignition changes are needed to suit.
The age old problem with the OEM ecu of hitting rich/retard will also raise its head. Simply adding a FMIC, free flowing pod inlet, and 3 inch exhaust can be enough to give problems in that area.
Nistune could be your answer.
TD05 18G could be a reasonably good match but the HG options seem to have been proven a very good match. No reason to ignore the Kando unit though.
Edited by Dale FZ1
Thanks Dale. I do have the safc neo but of course more just for tweaking rather than redoing the tune. So plenty of ppl seem to run hiflows ok on stock ecu, guess the td05 is a different story tho. Pity, cause these are such a great price! And so much good feedback on their product.
If you can modify fuelling and ignition with the SAFC then that should do the job nicely.
You can't - S-AFC just modifies the load signal from the AFM.
In other news, local drags next weekend finally - looking forward to seeing how my mates S14 Silvia goes with the antisurge 16G setup, getting some ETs and trap speeds should clear up any dyno difference doubts. It will be running 19psi on E85.
Awesome, good luck. I'll be lying if I said I wouldn't be disappointed if it went under 115mph, but it's really hard to say beyond there - it's got a really difficult to "read" seat of pants feel, its surprisingly quick though. I'd kindof like to see around 120mph, but realistically anywhere between 115-120 would be well respectable for such a basic setup I reckon.
All the SAFC does is intercept the AFM signal and move it up or down, with this your fuelling may change but so will your ignition timing as the ECU will think you are under less or more load dependant on tune. Funnily enough though i have a Super Ignition timing converter for sale that could work very well for you ;):P
Lol thanks for offer...and sales pitch... But i'm ok. Yep i know about the safc/timing, or more impotantly, so does my tuner.
Anyway lets get back to the antisurge thing, ppl use and recommend?
LOL I guess we can talk about ECU's after the worst happens, if you prefer.
The general consensus on anti-surge is that you don't need or want it. Factual evidence to its pro's and con's are not readily available, but I believe the aforementioned is the opinion of most.
Be it myself I would be confident that a TD05H 18G 10cm would not necessitate an antisurge housing on an RB25. However, it should be noted that while an 18G flows a few pound less than a 20G, an EVO 3 spec 16G6 flows only 1lb/min (10hp rule of thumb) than a 20G, and is a perfect match for the TD05H turbine.
SO, again, be it myself I would be opting for the below unit in a 10cm (RB25, use 8 for 20) as the replacement to a highflow:
http://shopping.kinugawaturbo.com/kinugawaturbochargerbolt-on24inchesnissanskylinerb20detrb25dettd05h-16g8cm10cm.aspx
Wanting to get some advice on internal or external gates if someone could spare a few minutes.
Have just had my RB20 tuned with the following:
Stock RB20 internals
Z32 AFM
Bosch 630cc Injectors
Walbro Fuel Pump
PowerFC
GTR V-Spec II Coil Packs
Standard exhaust manifold
Chinese front facing plenum, standard runners
Generic looking FMIC
3" exhaust, pod filter
Kunigawa TD05-18G Anti Surge, internally gated.
15psi spring (I think)
Turbo Smart bleed valve
here is the Dyno graph, all looks reasonably normal
ep5j0W3.jpg?2
The problem I have is that it shoots to 15psi pretty quickly, then it sort of sits there for a bit until around 6 - 6500rpm then goes to 19psi. It just seems like the IG isn't really doing its' job, is it going to be worth spending the $500 or so it will cost to go external gate?
The external gate does more than just control the boost though, it also flows better in the top end improving power/torque output. It's a great mod if done correctly, and perhaps hidden for defect reasons.
If you just want to control the boost a little better, you will need to die grind the existing wastegate for better flow, or get Hypergear to weld on an enlarged puck and machine it out.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
