Warranty is the biggest issue here having to pay $160 for postage and then another $160 if u don't want your turbo to be abandoned in case the workshop in Taiwan is closed then the most likely chance of paying a further $350 when they decide not to warrant the warranty. I think taos ss3 makes more power and response then these anyway and is in Australia. Well around around the corner for me, which makes everything everything that much easier and safer just a word of warning for anyone wanting to get one
Always worth updating the thread - interesting to hear, though strange it's contrary to years of use by people here! A mate had to return something along the line too, when they supplied an 18G instead of a 16G - and they sorted him out quickly... the customer service for folks I know overall hasn't been bad, did they give a reason as to why they didn't honour the warranty?
In some cases I would potentially take Hypergear more seriously as an option if I lived in Oz too, but in NZ Kando Dynamics makes more sense cost wise and in terms of knowing what you are going to get.
The comments seem to indicate that warranty has been honoured in each instance - correct?
Consumer having to wear the $160 shipping cost is not so good but if Kando have rebuilt/repaired at their cost I feel it's hard to have a gripe.
360 degree thrust bearings have been the way to upgrade turbo reliability since Adam was a boy - I seem to recall there is some sort of option along those lines available from Kinugawa?
Good good :) Occurred to me recently a lot of people seem to be getting failures over there and I was shocked to find "no BOV" was a trend in Oz. AFAIK (could be wrong?) thrust bearings get hammered when you get compressor surge, which would be massive without a BOV.
A lot of people getting failures? Or people getting a lot of failures? :ph34r:
  • Like 1
Heard of 2 people today having exactly the same problems with a td06. Seems like the first few batches at at the start where made perfectly then once his name got bigger the quality control has gone down hill. Happens a lot with a lot of big brand stuff
I get to work on them often, the shaft and bearing below came off a Kando T67 sent in last week, like I've mentioned earlier. This issue happens to T67 or those larger billet L2 based cores working with Rb25det engines on high boost. When compressor out flows turbine creating way too much back pressure.
That's interesting. Any theory on why SimonR32 (first post: http://www.skylinesaustralia.com/forums/topic/347726-kando-dynamics-turbo/) has been running the T67 25G for years without issues?
Thanks for providing input - I would definitely like to know if reliability has changed or is worse than previously evidenced from this thread, as I definitely don't want to be recommending a product which is going to cause people issues. In saying that, again I'm not like to recommend mismatched turbos to people anyway... so the likes of a TD05-16G6/TD06SL2-20G/TD06-25G should be comparatively safe?
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
