Interesting, is that on a 2.6,2.8 or 3.0, I have had good success with the twin GT-RSs so far but the exhaust side is becoming a restriction on the 3.0
So even the TD05s with the slightly bigger exhaust wheel and a good comp wheel should help
Will be interested to know if the 68HTA comp wheel can be fitted to either TD05s or TD06s
This is in reference to 2L motors in single IWG configuration.
I believe that the resultant geometry of the enlarged housing (its made for TD05H wheel) is not adequate for the 61mm TD06SL2 and the character sucks. Both parties I know of have struggled to exceed much over the 200kw mark. A change of turbos has resulted in far superior results, one of them switching back to a Kando TD05H-18G (T518Z).
I think the mentioned 9 blade TD05H combined with the 68HTA wheel could be mighty promising at your level, but am not sure the cost exercise would yield benefits over pre-fabed Kando billet 16G units.
Never heard of that issue but don't really know anyone who has tried a T25 TD06 kando off the top of my head... Though I was sure I had heard of them.
A really quick Google brought this totally reasonable result up and no evidence of any dramas, can you point us at any reads on the drama you are talking about?
http://www.tamparacing.com/forums/nissan-infiniti-tech/814254-kinugawa-20g-turbo-review.html
Sent from my GT-I9505 using Tapatalk
Hypergear mentioned some thing about housing geometry in their latest T28 turbo. Not sure what size they ended up using, their latest ATR28 ss2 is pretty amazing for a little SR.
He cropped the larger turbine until it was the maximum size the T28 housing could accept.
Lith, 260 is a very reasonable result. The two I know of (known from face to face interaction) failed to exceed 220kw.
Well it seems it is definitely possible, hard to know what to read from it when a couple go wrong... Entirely possible there was something else at play there but with so little info it's a bit hard to make a sweeping judgement. I do know someone who recently had a poor result with a completely unrelated brand of turbo where someone shoved a big wheel into a non native turbine housing and that bombed quite badly so it seems plausible I guess. I wish I could remember where I am sure I heard or saw someone with a similar combo which made good power, as it was discussed when we were plotting development for my mates S14. The 16G was selected because it was going to suit better, we had no indication or assumption a T25 TD06 would underperform, well aside from the fact that with stock cams it wouldn't make too much over 200kw on petrol.
. Hence not being considered a great match for his needs as he was unlikely to upgrade anything else for sometime to come
I know this question has been asked many times but If any one has first hand experience with the Kinugawa Td06h-20g 8cm Rb20det bolt on kits that are internally gated Please Say what you think.
Ive heard that the gates are to small and cause bad boost spike?
Ive been told they dont spike as much if you run a higher Boost through it ( around 18 Pound ).
Ive tried to search other places and havnt found much, just people bagging them out.
I don't have first hand experience but have read In other forums that people are just modifying the waste gate and having no problems at all. I know they get to it with a die grinder and bore it out a bit and the flap seems to be fine how it is.
T67 looks like its going to fit fairly easily with a 25mm or 30mm spacer
looks like there room to go even bigger turbo (if air con is removed to make the inlet easy)
(this is on a 34 gtt) I'll post pics once I find a spacers that's not $95
feel free to tell me what stud sizes I need to :)
For some reason I thought I responded to this - of course they can :D I had even been pondering trying to buy some bits and making some hybrid things to experiment with though I'm not sure if I am THAT motivated.
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=68HTASale&Category_Code=SP
It fits fine, I even managed to fit one low mount on an s14 with a little grinding.
Make sure the spacers are the shape of the hole in the manifold, not the size of a T3 gasket which is much larger.
I thought you had too :), that is very interesting, how hard would that be to get "GTR" housing to make it a bolton for RB26s, looks like I might be up for new turbs soon so that maybe an option, the billet Kando bolton TD05-18g are what I was thinking but these give me something to think about
I wouldn't imagine it would be ridiculous, just get the Kando housing (or something that will bolt onto the Mitsi plate) and modify it to suit the profile. In my make believe world where I have more engineering skills I like the idea of designing a custom RB26 bolton housing that has a diffuser area etc which better suits the 68HTA wheel, etc. I am sure that a turbo with matching (where it counts) outlines to the stock RB26 housings could have better flowing internal geometry, to allow for the 40-50lb/min flow per turbo you need for stock mount madness.
Just run those housings. They are circlip compressor covers so easy to clock them however you want. Just weld alloy inlets to the compressor cover...I think they would simply be too big, even on an RB30....though would be sure to make uber power considering a friends twin TD06-20G 2.7L made something like 550rwkws on race fuel years and years ago.
Yeah I would consider either to be most suited to the lunatics who would otherwise be putting a big single on their car but want it to be low key, under the bonnet at least haha
Yeah I would consider either to be most suited to the lunatics who would otherwise be putting a big single on their car but want it to be low key, under the bonnet at least haha Sent from my GT-I9505 using Tapatalk
Lol yep that would be me :D
The T618z are what I wanted for this build but couldn't find any for sale and settled for Piggys GT-RSs, and as much as they make good power with decent response on the 3.0 the exhaust side is choking it
Now that I'm getting a bit of white smoke I'm thinking they are on their way out so now trying to decide between TD05s or 06s, I think the TD05s with the billet 18g comp wheel and 9 blade rear should show decent improvements on what I currently have with out hurting the response to much, but then there is the TD06s with the billet 20g wheel and 9 blade rear that would make massive power for low mounts but at what cost to response
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
