Yeh, I was so, so , so tempted to try the 68HTA. It is meant to flow about the same, perhaps a little more and be more responsive. In the end the decider was if I was going to make a change then make a change. The 15% more flow was the decider. I also thought that once I see how these all work, or dont then I can always hot rod the TD05H with the 68HTA compressor :)
Now to see how well the lil RB20 uses the extra flow
Yeh, its only done dyno time so like new. But nobody is going to pay $2200 for it when you get get a "Kando the Great" for $800.
If I had an RB30 i dont think i would run any of these turbs. I think you would get a better result out of the GTX3076, more responive and the billet compressors seem to give you a bit more legs at higher pressure ratios. So probably bag you a more responsive 350rwkws.
What about a T67 on an RB30??? That gives me a 3/4 chub just thinking about it :whistling:
got 2 on the boil :)
Love the Kandos.... just not the int gate ones... they fall in the fail catergory for output when compared to thier ex gate cousins... back to back has shown 20-35rwkw losses :down:
Yeah very true Roy, it is pretty amazing value for money. The problem with the GTX turbo's is the price. That is a major turn off. But maybe I should do a little further research into them.
One issue I had with the T518Z Kando I used was the IWG path and turbine inlet path design..
There was actually a hard edge in the flow path, I have drawn a diagram to show what it was like:
Note that the unshaded area was not curved or shaped in any aerodynamic way, it was simply a hard edge in the flow path.
Hey Trent, you wouldn't be able to post a dyno print would you? showing the boost response preferably. I don't care if there a kando or a Trust version. what would be your personal preference on a street driven Rb30 with a goal of upto 350RWKW? T67-25G, TD06H-25G, TD07S-25G or any other affordable config.
regards
Chris
regards
Chris
this is a good example of a td06h-25g 10cm (will post graph fri or sat when i get to the shop)
over 400rwkw and 4200rpm it reaches it target boost threshhold of 24-25psi
i would go 12cm trust version on a rb30d
If Kando starts making 'proper' internal gated versions of their turbos (with a re-designed wastegate flow path) that work, with a Skyline 6-bolt dump flange, nobody would buy Hypergears or even Garrets anymore.
At the price these Kandos are going, they are just unbeatable. Somebody please push Eiji to do a few design changes to make the above turbo..Do Eeet.
There has to be more to the story?!?!? What fuel and what capacity and mods does the SR20 have? And whilst it boosts 24psi at 4,200rpm what power is it actually making at 4,200rpm. On a well sorted RB25 with thicker headgasket, Greddy inlet, Tomei cams and complete TD06SH-25G setup...
At 8,000 rpm it has 308 rwkw
At 7,000 rpm it has 320 rwkw
At 6,000 rpm it has 296 rwkw
At 5,000 rpm it has 230 rwkw
At 4,000 rpm it has 114 rwkw
That was on a dyno that read about 20-25rwkws lower then other dynos it went on and was a pretty conservative ignition map on 98 tune. No doubt it could be improved but massive divide between 360rwkws and 400rwkws out of a 25G compressor?!?!?!
I have a soft spot for the TD/Mitsu range of turbos. But in cases where people are putting turbos on built motors with external gates etc then what is an extra $1000 on a Garret or other turbo IF it gives you an extra 40rwkws at 4,000rpm and matches the top end? Bang for buck its up there...but personally I would bin my Trustck turbo if I could find a sharper tool in the shed :)
rondofj, i choose you!!!!!!!
the email is a few pages back, get cracking
Dont choose me mate, you have far more experience/knowledge on turbos than I do,.. but I might just send him an email sometime soon...
If my twin setup sells from my GTR im going single kando...
Which one though? Need response but over 450hp at wheels.
Current -9's have 400hp 19psi safely.
There is only one answer -_- join Simon on teh epic side
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
