I've been waiting around 6months, a little longer won't hurt I guess.
So have you heard that they will release 10cm housings Roy? Or did you mean I may get lucky and come across a turbine housing?
Edited by JLTS13
Have you thought about trying an 8cm? Maybe it wont be as bad as you think.
The 3 bolt flange is said to flow 30% more than a square flange, maybe with a big gate it will work fine and be even more responsive? You could always try.
Gtscott I think that's what I will try, can't see the harm in giving it a go. And I can always change the housing at a later date.
Im interested anyway to see how it fairs against the 10cm on a rb25
And I'm running a 50mm gate so maybe it may help control it a bit
Edited by JLTS13
Got a dyno sheet? There has been some interesting discussion on how much the TD05-18G can make. Is yours an external setup or internal? Love to know what it will make on pump :)
Yeah got one but just got to load it up
Internal gate
And I had the same turbo previously on pump 98 made 231rwkw on 19psi but I only had 555cc injectors then so was limited by them not the turbo capable of more with more boost like now
Still ran a 12.5 @118mph at wsid with 231rwkw I'm hoping I can run a high 11 now with the extra 22kw
Edited by hy_rpm
Internal gate
Your not the dude I met at St Marys station for the .64 housing are you?
Roy I read it on the FP site amongst other places.
Actually its sold lol, collected money for it yesterday.
Im confident theres nothing wrong with the disco itself but its a bad match to the high comp motor and the cams are also shit.
I did say you would make the 250-260 mark mate. A nice result, but like weve been discussing theres possibly more in it with another exhaust housing, probably not worth the hassle tho.
How responsive is it on the street?
so having issues getting mine tuned atm. its only making 230 at 1bar
it hits full boost by 3700 (20psi, my tuner says this is very fast for this size turbo)holds it flat to about 5000rpm and dies back down very quickly to 1bar (gate pressure).
initially thought it was the BOV leaking so my tuner blocked it off and it helps a bit but it still dropping off fast after 5000 rpm.
my tuner has double checked everything and can't see anything wrong with the setup or any loose clamps or hoses.
his conclusion a) the rear housing is too small for it to drop off so fast up top (even if it was the smaller housing, the 8cm it should still hit 250~ and hold boost flat like BSA's results) or b) the manifold is restricting (but its been proven that the stock mani is good for 300 so that rules out the mani).
i did question a few pages back why the kando rear housings were so small compared to Trust/Greddy items but then its the same rear hats on simons T67-25G and he hasn't had any boost issues.
td06sl2-20g
stock manifold
tial wg44mm (1bar spring) plumbed back to exhaust
greddy profec B Spec2
no cat
hybrid style cooler with 2.5" piping
3" alloy intake with 3A racing filter
any ideas guys? pretty disappointed right now.
Have you considered the gate mod to the manifold might be holding it back? I wonder what would happen if it was plumbed off the rear housing instead with an intact manifold.
And that is some pretty rapid spool. Will be interesting to see the final result. Don't forget Jez has the same turbo and housing.
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
