what would be the closest equivalent to a gt35r with 1.06 rear?
TD06H 25G 12cm
For people unaware this is being suggested because he is used a 4.5L motor, it is not the all out performance replacement to the 35R.
You would want this if you are after a kando:
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Anti-Surge-TD06H-25G-T3-12cm-/270807644010?pt=AU_Car_Parts_Accessories&hash=item3f0d64b76a
Or this may be a lot better for your application:
http://www.ebay.com.au/itm/Turbocharger-HINO-JO8C-24100-3251-GARRETT-GT3576-479016-/290609084681?pt=AU_Car_Parts_Accessories&hash=item43a9a6b909
Better spread of torque, not so much 'performance' based. Will do more of the heavy work that a 4by would normally do.
TD06H 25G 12cm
http://www.ebay.com....=item3f0d64b76a
http://www.ebay.com....=item43a9a6b909
Thanks for your help. I've been looking at this-
http://www.ebay.com....=item3f0d202c19
What do you think? I'd prefer IWG
Edited by O2 Autosports
ok , so theese are dimentialy the same, just not actually made in japan using quality materials. but are one of the better "bing whoa" coppies?
I hear they are made in dirty backyard toilet labs by unsavoury types using battery acid and horse tranquilizers .. :whistling:
The IW housing they have is very similar to the Trust 12cm item. Try to stick to both 12cm or bigger and the TD06H wheel.
Incase you havent read the whole thread, the following are the TD06 wheels in size and flow:
TD06S 65mm OD - lowest flow
TD06SL2 61mm OD - high flow good balance with spool
TD06SH 67mm - highest flow
They all have the designation 'S' whether it says it or not. Do not confuse a TD06Sh or TD06H as two different items, they are the same. Some tend to drop the S as its not needed.
You have a giant engine so I encourage you to stick to the biggest parts you can.
Try look for a TD06H 25G with 12cm rear housing and 24v front cover. Maybe email them to ask if they can make this and for under $800....
how would these kando turbos compare to a hypergear turbo, reliability and performance wise? or is that a how long is a piece of "insert very long material" question?
Yes, how long is a piece of string fits well. The better question is what do you want...... Kando has got a lot of cars covered, Evos, Subys, SR20s and generic.
The skyline stuff falls into the generic catagory, which need custom everything that touches the turbo. Custom manifold, custom wastegate, custom dump pipe. Even the internal wastegate turbos kando do will need custom dumps and spacers off the stock manifold.
If you like what you see from the T67, get one and get the bits mentioned necessary to make it work.
If you want it to bolt on and fit easily, have a look at Hypergears current turbos and pick the one which makes the power u want.
At the end of the day its power and method. Some of us would prefer a 20g over the HG SS turbos, fast spool and up to 300kw. There is likely to be little benefit at the end of the day... And it will need a manifold and gate whereas the HG will not.
Answer: if you want less than 300kw just get a HG. If you want 300+ get the T67. If your not sure, also get the HG because the Kandos will need some serious effort applied.
For under 300kw I would go the HG every time, fitment wise it bolts on with very little drama, internal gate so looks stock, great response and power, they are also cheap. Kandos are cheaper but you need manifold, dump and gate, so by the time you are finish they will cost more most of the time, however if you already have this stuff it is a no brainer.
Reliability wise from what I've seen and read both the turbos are as reliable as anything else, probably don't have the same quality control as a garret, but you don't see random failures like cheap generic china stuff that has very porous casting and other average stuff.
how so?
have you tried one yourself?
The only T3 IWG they do is a 12cm, which is a little lazzier than I most of us seem to want.
It also has a 3 bolt outlet which blocks the WG path... There is also an open version (same thing with the rear cut off) which I think fixes the problem bar that of the 12cm.
Keep in mind MHI seem to like smaller housings, 12cm is more 3L suitable. If they were TS evo housings that is a different game all together.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
