even with all the issues its looking good man.. :thumbsup:
Ed..just realize you tuned on eflex, Im hoping to make that power on PULP at around 18psi..
just wondering did u use the water lines from the kit and just join them up to some rubber hose as well...its a dodgey setup and i had a time actually getting the fittings to stay tight on the turbo..Im hoping heat will maybe fuse them in place somehow..lol
I always use braided lines, i remove the standard metal part of the coolant pipe from around the back of the head, cut it and get a fitting brazed on. Then i can connect my braided line to it and then refit the metal pipe back into the stock rubber hose behind the head.
This way has always worked well on rb25's but rb20's have a 2 metal brackets behind the head and can be extremely hard to remove
That's an awesome result man. Once you get a decent sized gate on it and wind some boost in youll be laughing.
I think most of these guys havent realised that the turbo should be nowhere near its peak efficiency yet. Not using VCT would be a total bummer and robbing you of response, your boosting it between 11 and 15 psi when they want over 18 to even roll out of bed and your using a mainline dyno which tend to be heart breakers in terms of power.
I think on the right boost it would easily match those figures on 98, given the above. You should have pioneered a 98 tune before you hit teh flexxx. Im about to SMS you too.
Nice result, though the max flow a 20G will give is not a lot over 18psi - I'd not be too surprised if the turbo starts getting way out of efficiency trying to push more boost than that on an RB25, no doubt the E70 will give a bit of headroom for making some more power despite that though. If you've seen cars make more going higher its probably more than the engines need the boost, than the 20G itself.
Will be very interesting to see how it goes with the boost wound up a bit more and the misfire solved, there should be a fair bit more than that to be got yet :)
VCT is disabled in my car so hopefully it doesn't kill too much response.
full boost by 4000-43000 is acceptable :D
very good results so far Jez, i am assured i made the right turbo choice.
i rekon at 20psi, ill pull around 280rwkw and i'll be happy.
try with a lower PSI spring and a better boost controller.
i had this issue with boost not holding on a 38mm turbosmart, installed the 7psi and EBC and all was sweet.
Ebc is Probably needed but its a very low budget car just to show with the right choices what results can be made.
Lithium u are probably right, tho im gonna try 18-20psi anyway :D
Even before i tuned this car properly i could tell by testing it at home that this turbo and combo was impressive. For it to light 3rd gear up without full throttle i was very impressed
SimonR32...care to step in and help out with the wheelspin in 3rd gear AWESOMENESS :)
Great result. Hurry up and give the thing a belly full of boost as I am curious to see what the 20G compressor can flow on E70
Fixed
Thats what this car is built for. Skids
Haha Roy, you are onto it :)
DVS JEZ have a look at my build thread about subframe alignment play around to get power down better.
I think this is a average result but shows a lot of potential when the boost and misfire are fixed... I'm tipping 325rwkw with 15psi in 4th gear on the road at 3200rpm :thumbsup:
Nice. Ill get the vtc sorted too. This car isnt going to be registered so its abit hard to do any on road testing. Ill post up some vids from thursday trackday.
I have a R32 GTR rear cradle but i cant be stuffed to fit it with offset bushes etc. Just wanna drive it.
Great result so far, looking very interesting. My SS1 made 244rwkw on 98 fuel and 279rwkw on Caltex Eflex so everyone can get a rough idea that it would be around 250rwkw on 98 fuel in its current setup. Keen to see what it does with everything sorted!
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
