Well, after owning the stag for just over 4 years now and driving it pretty much as it came. I have almost completed my 1st couple of mods/additions.
I purchased a Turbo Tech MBC off ebay & after trolling thru a stack of threads I managed to get it fitted the way it should. I also bought a boost gauge & air/fuel gauge from one of the skyline boys, purchase a few bits & pieces from my local auto shop & fitted them below the radio in my centre console. StagMBC_2.jpgStagMBC_1.jpgStaggauges_1.jpg
Any suggestions on what I should put in the 3rd gauge slot???
Just fitted V spec Brembo all round , crap !!!! , is there a certain bleeding procedure ? , whiteline Anti roll bars front and rear , Awesome ! , front adjustable upper arm bushes , camber better ! ,
oil pressure
unplug the abs
bleed the rears, furthest from brake master (bmc)
bleed fronts (both sides of each calliper)
plug abs back in
Looks sweet once it's done eh?
Yep. I ended up putting on the darkest legal (30% i think?) as I got pulled over earlier that week and was told my rear windows were illegal. (factory stained glass from nissan) Haha.
^^ police are becoming stupider by the minute.
I had mine done 20%whistling.gifthey're almost exactly the same as the back. If it didn't look so cool, it'd be a pain in the arse...
I figure if I ever get pulled over I'm going with "it's all factory tint" If that doesn't fly, I'll just strip it , inspection, re tint. Mine only cost $100 for the pair.
I got me an oil pressure gauge, only thing is its too big for the slot. Was thinking of mounting it on the A pillar at a later date. Any other suggestions......maybe voltmeter?
BTW............forgot to mention that I made the plate for the gauges to sit in, dead easy.
IMO if you are going to run multiple gauges, the most important ones will be boost, oil pressure, oil temp and water temp.
Thanks, probably put water temp in the open slot in centre console. The oil pressure gauge is too big to mount under radio, so I'll look at making dual A pillar mount out of fibre glass for oil pressure & oil temp.
Just bought the 'power duct' through Nissan. Looking forward to saving that amount of money over the next 8years 5 months (HAHahahha) in fuel economy from sucking in hot air from the engine.... :rolleyes:
looking at connecting the fuel/air gauge 2d. pwr connected, just need to run sensor wire to the heated O2 senser on the ECU (pin 50) if I'm not mistaken.
Waste of time, unless you get a wideband sensor.
Oil pressure, oil temp, exhaust temp, accurate water temp and wideband are all critical if you are tuning imo.
OK then how fo you know if its wide band??? or not. The one I got is Autometer Pro Comp Ultra Lite (refer above pic). Shows - lean, stoich & rich.
A wideband wont run off the ecu, it requires a wideband o2 sensor to be placed in the dump. It will give you an actual value instead of just rich/lean.
This is the one I have...
http://www.innovatemotorsports.com/products/lc1.php
SHWEEEEEEET, something to save for asside from the home loan :D Thanks for the info, i also had a quick look at the new autometer clip for their wideband sensor/gauge.
Anyways, gonna finish wiring this up so my acr is ready for the trip to Dubbo 2m
got my intercooler today
ITS THE WRONG FKING ONE
sigh.. now have to way another 30 years for it to get here... and the fact that this "flood" has nothing to do with WA or where i am ordering my cooler from, it will still take bloody ages... so angry
well today i got the dump exhaust off..to fix the exhaust gasket leak.exhaust.. turns out there was maybe 1mm of the flange that WASNT leaking. When I pulled it off to fix it, it looks like the exhaust shop that did the exhaust did a dodgy, and shrunk the 3" to about 2.5" and put the stock flange back on (never taking it there again). Scotty the f**kn legend cut some of the exhaust off put it back to 3" with a new flange.. fixed.
Ok so made up a new gasket from Gasket material, with some gasket/exhaust seal. n put it back together..
it set.
Started the car.. i'de safely say about 50% of the turbo whine went away...sounds normal now..
still gonna take it to the turbo shop on monday to let him have a listen first..
once this all finished. i made some great souvlaki's and now im full and scotts so full he cant breathe!. goodnight Stagea owners.!
Edited by AaronNM35
that turbo whine you were hearing is awesome. LOVE the sound of the turbine when you have an exhaust leak :)
my bosses car has a dump straight to the ground from the turbo, i love driving it just to hear that sound. pity its attached to a mazda6 MPS
    • WhatsApp+35796370243 Email: [email protected] Telegram: @tesgkm Vásárolj hamis pénzt, és segíts az embereknek szerte a világon elérni céljukat, hogy jó életet élhessenek, és megengedhessék maguknak azt, amit soha nem engedhetnének meg maguknak. Az én pénzemmel. Megvan. Valóra váltom az álmaidat, a világot eléd tárom, a közeli barátaid tisztelnek, az ellenségeid tisztelnek, és a legjobb életet biztosítom neked és a családodnak. hamis euróbankjegyek vásárlása hamis bankjegyek vásárlása Hol lehet hamis pénzt vásárolni? Hol lehet hamis játékpénzt vásárolni? Hol lehet hamis pénzt vásárolni? Valódi kinézetű hamis euróbankjegyek Eladó valódi euróbankjegyek hamis pénz vásárlása online észlelhetetlen hamis pénz vásárlása online hamis pénz vásárlása online az USA-ban valódi hamis pénz vásárlása online hamis pénz vásárlása online hamis golyók vásárlása hol lehet hamis bankjegyeket vásárolni hamis bankjegyek vásárlása online hol lehet hamis 100 dolláros bankjegyet vásárolni hol lehet hamis dollárbankjegyeket vásárolni hol lehet hamis millió dolláros bankjegyeket vásárolni hamis euróbankjegyek vásárlása hamis dollárbankjegyek vásárlása hogyan lehet hamis pénzt szerezni? hamis 20 dolláros bankjegyek hamis bankjegyek ellenőrzése Egy kényelmes otthon nagymértékben javíthatja az életminőséget. A pénz lehetővé teszi, hogy biztonságos, védett és kényelmes lakóteret biztosítson magának és szeretteinek. Milyen jellemzők vagy szolgáltatások tennék álomotthonná a házat?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Buy Counterfeit money and Helping people around the world to achieve their goal to make them have a good life for them to afford what they can never afford With my kind of money. I have. I will make your dreams come true make the world ahead of you make your close friends respect you make your enemies respect you and give the best life for yourself and your family. buy counterfeit euro banknotes buy fake banknotes Where Can I Buy counterfeit money where can i buy fake play money where to buy counterfeit money Real looking counterfeit euro banknotes Real euro banknotes for sale buy counterfeit money online buy undetectable counterfeit money online buy counterfeit money online usa buy real counterfeit money online buy counterfeit money online buy fake balls where to buy counterfeit bills buy fake bills online where to buy fake 100 dollar bill where can i buy fake dollar bills where can i buy fake million dollar bills buy fake euro bills buy fake dollar bills how to get counterfeit money counterfeit 20 dollar bills checking for counterfeit bills Having a comfortable home can greatly improve quality of life. Money can provide the means to afford a safe, secure, and cozy living space for yourself and your loved ones. What features or amenities would make a house feel like a dream home to you?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Money plays a huge role in our lives.Buy counterfeit money. It's needed for basics like food, shelter, clothing, and healthcare. Beyond that, it provides opportunities for education, travel, and personal growth. Financial stability can reduce stress and give people the freedom to pursue their passions. However, it's also important to buy counterfeit money, remember that money  isn't everything, Buy Fake Bills. for relationships, health, and happiness are equally vital. How do you think people can strike a balance between making money and living a fulfilling life? buy counterfeit euro banknotes, buy fake banknotes , Where Can I Buy counterfeit money, where can i buy fake play money, where to buy counterfeit money, Real looking counterfeit euro banknotes, Real euro banknotes for sale, buy counterfeit money online, buy undetectable counterfeit money online, buy counterfeit money online usa, buy real counterfeit money online, buy counterfeit money online, buy fake balls, where to buy counterfeit bill, buy fake bills online, where to buy fake 100 dollar bill, where can i buy fake dollar bills, where can i buy fake million dollar bills, buy fake euro bills, buy fake dollar bills, how to get counterfeit money, counterfeit 20 dollar bills, checking for counterfeit bills, Buy undetectable counterfeit money, buy fake money that looks real online, where can i buy fake money that looks real, where can i get counterfeit money, Money is a necessity! People need it to cover basic expenses like food, shelter, and clothing, as well as for savings, investments, and achieving long-term goals. Financial stability can reduce stress and provide peace of mind. What's your take on financial planning or money management?
    • Whatsapp+35796370243 Email: [email protected] Telegram: @tesgkm Kupujte ponarejen denar in pomagajte ljudem po vsem svetu doseči svoj cilj, da si zagotovijo dobro življenje, da si lahko privoščijo tisto, česar si z mojim denarjem nikoli ne morejo privoščiti. Imam. Uresničil vam bom sanje, ustvaril svet pred vami, naj vas spoštujejo vaši bližnji prijatelji, naj vas spoštujejo vaši sovražniki, in zagotovil vam in vaši družini najboljše življenje. Kupiti ponarejene evrske bankovce Kupit ponarejene bankovce Kje lahko kupim ponarejen denar Kje lahko kupim ponarejen igralni denar Kje kupiti ponarejen denar Pravi ponarejeni evrski bankovci Pravi evrski bankovci naprodaj kupiti ponarejen denar na spletu kupiti nezaznaven ponarejen denar na spletu kupiti ponarejen denar na spletu ZDA kupiti pravi ponarejen denar na spletu kupiti ponarejen denar na spletu kupiti ponarejene kroglice kje kupiti ponarejene bankovce kupiti ponarejene bankovce na spletu kje kupiti ponarejen 100-dolarski bankovec kje lahko kupim ponarejene dolarske bankovce kje lahko kupim ponarejene milijonske dolarske bankovce kupiti ponarejene evrske bankovce kupiti ponarejene dolarske bankovce kako dobiti ponarejen denar ponarejeni 20-dolarski bankovci preverjanje ponarejenih bankovcev Udoben dom lahko močno izboljša kakovost življenja. Denar lahko zagotovi varen, zaščiten in prijeten življenjski prostor za vas in vaše ljubljene. Katere lastnosti ali ugodnosti bi vam hišo naredile kot sanjski dom?
    • Whatsapp +35796370243 Telegram.@tesgkm O dinheiro é uma necessidade! As pessoas precisam dele para cobrir despesas básicas como a alimentação, a habitação e o vestuário, bem como para comprar dinheiro falso para poupar, investir e alcançar objetivos a longo prazo. A estabilidade financeira pode reduzir o stress e proporcionar tranquilidade. O que pensa sobre planeamento financeiro ou gestão financeira? Compre notas falsas online. comprar notas de euro falsas comprar notas falsas Onde posso comprar dinheiro falso? Onde posso comprar dinheiro falso falso? Onde comprar dinheiro falso? Notas de euro falsas com aspeto real Notas de euro reais à venda comprar dinheiro falso online comprar dinheiro falso indetetável online comprar dinheiro falso online EUA comprar dinheiro falso real online comprar dinheiro falso online comprar dinheiro falso online comprar bolas falsas onde comprar nota falsa comprar notas falsas online onde comprar nota falsa de 100 dólares onde posso comprar notas falsas de um dólar? onde posso comprar notas falsas de um milhão de dólares? comprar notas de euro falsas comprar notas falsas de um dólar como obter dinheiro falso? notas falsas de 20 dólares verificando se existem notas falsas A crise atual é realmente difícil, com muitas empresas e negócios a fechar, deixando as pessoas com dificuldades em sobreviver. É um verdadeiro desafio cuidar das famílias e pagar as contas quando as fontes de rendimento estão a diminuir. Que tipo de apoio ou recursos considera que seriam mais úteis para as pessoas afetadas?
