people feel that they're fiddly things, when adjusting gains and etc.
but everything that comes out of japan is fiddly. lol people should deal with it.
Yeah mostly I think it is people not reading the manual and/or taking the time to set them up properly. It's not quite as simple as "I WANT 20psi, K.. GO!"
Also, some think they can't handle huge boost and prefer to go for the Blitz dual solenoid units. The theory there is that the dual solenoids can handle fast ramping, huge boost setups better.
Got it thumbsup.gif I dont see either of those issues being of particular concern to me - but good to know! cheers.gif
Defiantly are not plug and play.....took about half an hour of run's to set it up in Andy's car yesterday!...mainly because it takes so long to get to 60km/h :P
Edited by Jetwreck
thats normal though, like bubba said, you cant just input 20psi n say go. 30minutes is actually pretty good.
Did the RDA slotted rotors and EBC pads (red at the front, green at the rear) tonight; and a full bleed of the brakes. Waaaaaaaaaay more bite. Good upgrade, very straight forward :thumbsup: and, no brake squeal! :worship:
I did the same thing 2 months ago on my r32 GTR callipers, those RDA slotted rotors are great, no warp at all when you heat them up. I used the QFM A1rm's and they bite well, better than my EBC reds. Once they are hot though, my god they pull up! Better than any brakes I have felt before.
+1 for the QFM A1RM's
I wasn't really a fan of the EBC's as when I bought a set they would dust something shocking, and this dust would EAT the wheels! Pads were pretty good. Pretty average when cold though!
Dunc, just make sure you change your fluid to something with a slightly higher boiling point. The increase efficiency of the pads at operating temperature means you are bouncing up closer to the boiling point of standard brake fluids, giving your nice new pads a squishy pedal!
We bled them and put in a mid range PBR fluid; nothing too extravegant but better than what you'd get if you took it to a generic mechanic. I had the 'faded brakes' convo with my mate whilst we were doing the brakes, he felt pretty comfortable that what we were doing would be fine thumbsup.gif.
Even when cold, the new setup felt like it had a heap more stopping power than what I was driving this time yesterday - but given I changed so many components at once I wouldnt be so bold as to attribute it to 1 particular bit; as a whole - the system is working nicely. I'll keep an eye out for that brake dust though pirate.gif
The dreaded cold start ethanol issues? You may just need more fuel at cold start, do you have the Emanage software working yet? See if the temp sensor is hooked up to it mate. Not hard to fiddle with it...
Why is yours clogged? What's the symptoms?
I'm having cranking issues in the morning. Do I need extra volts to the fuel pump? New filter?
nah no problems for me.. just wanna get one so after the 2nd tank of ethanol i can change the filter, it cleans the tank..
well we all were having cranking issues and popping on Idle.
get some air flow meter cleaner, and clean the AFM.
Fixed my problem instantly.
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
