people feel that they're fiddly things, when adjusting gains and etc.
but everything that comes out of japan is fiddly. lol people should deal with it.
Yeah mostly I think it is people not reading the manual and/or taking the time to set them up properly. It's not quite as simple as "I WANT 20psi, K.. GO!"
Also, some think they can't handle huge boost and prefer to go for the Blitz dual solenoid units. The theory there is that the dual solenoids can handle fast ramping, huge boost setups better.
Got it thumbsup.gif I dont see either of those issues being of particular concern to me - but good to know! cheers.gif
Defiantly are not plug and play.....took about half an hour of run's to set it up in Andy's car yesterday!...mainly because it takes so long to get to 60km/h :P
Edited by Jetwreck
thats normal though, like bubba said, you cant just input 20psi n say go. 30minutes is actually pretty good.
Did the RDA slotted rotors and EBC pads (red at the front, green at the rear) tonight; and a full bleed of the brakes. Waaaaaaaaaay more bite. Good upgrade, very straight forward :thumbsup: and, no brake squeal! :worship:
I did the same thing 2 months ago on my r32 GTR callipers, those RDA slotted rotors are great, no warp at all when you heat them up. I used the QFM A1rm's and they bite well, better than my EBC reds. Once they are hot though, my god they pull up! Better than any brakes I have felt before.
+1 for the QFM A1RM's
I wasn't really a fan of the EBC's as when I bought a set they would dust something shocking, and this dust would EAT the wheels! Pads were pretty good. Pretty average when cold though!
Dunc, just make sure you change your fluid to something with a slightly higher boiling point. The increase efficiency of the pads at operating temperature means you are bouncing up closer to the boiling point of standard brake fluids, giving your nice new pads a squishy pedal!
We bled them and put in a mid range PBR fluid; nothing too extravegant but better than what you'd get if you took it to a generic mechanic. I had the 'faded brakes' convo with my mate whilst we were doing the brakes, he felt pretty comfortable that what we were doing would be fine thumbsup.gif.
Even when cold, the new setup felt like it had a heap more stopping power than what I was driving this time yesterday - but given I changed so many components at once I wouldnt be so bold as to attribute it to 1 particular bit; as a whole - the system is working nicely. I'll keep an eye out for that brake dust though pirate.gif
The dreaded cold start ethanol issues? You may just need more fuel at cold start, do you have the Emanage software working yet? See if the temp sensor is hooked up to it mate. Not hard to fiddle with it...
Why is yours clogged? What's the symptoms?
I'm having cranking issues in the morning. Do I need extra volts to the fuel pump? New filter?
nah no problems for me.. just wanna get one so after the 2nd tank of ethanol i can change the filter, it cleans the tank..
well we all were having cranking issues and popping on Idle.
get some air flow meter cleaner, and clean the AFM.
Fixed my problem instantly.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
