nah factory wing, same as the one on Alex's PM35 and another one that was at the meet.
pic for you bigkev!
worth it purely because its my colour already
Edited by zei20l
lol it clips on, but there are 4 or 5 bolts underneath. youll need to remove the inside trim from inside the hinged glass tailgate section.
not a massive deal.
has your himount stop light died? mine too. i have a spare, but the non-wing models are different
Mine hasn't died- get back to me in 4 years time... then it will be as old as yours....:ph34r:
did you get a chance to check that diff out on the weekend? I know how far hassling you for parts will get me :P
nah i havent been there, but what am i checkout out on it? i thought you were coming to look at it?
I finished making the new fuel pump assembly today, all ready for the triple teflon braided lines. One Walbro HP and -6 line for each rail, it should just be able to max the injectors if I need it to. lol.
Hopefully the gtx turbo ships soon... :rant:
:worship: That looks like it'd set alarm bells off with ASIO :rofl: May have to get some details of your construction of this... eventually !
haahh thats some cool shit right there dude!!
not bad at all!! very clean
paint it black and no one will know its not factory.
how many PM35s do we have on here?
Cheers, yeh considering painting it black, or polish it a bit more.
I'm just not sure what to do with the breather line that usually goes back into the intake. Either make/buy a oil catch can or get a nipple welded on to it.
By the looks I need a new rubber joiner(from pipe to TB), it's starting to crack, so that'll be next!
just get a similar one like the blue silicone joiner you have.
then cut one side on a angle that suits the bend..or a bend silicone joiner
cutting the end is what I did and it works fine lol
make a nipple and put it back in if thats where its supposed to go. again, it will look factory and oil vapours will go back into the engine where they are supposed to lol
Not really. They go back in their because it was the easiest way from factory.
It's a proven advantage to vent them somewhere else. My RX7 has the breather go into a bottle... The optimal setup is a 2L+ bottle, with steel wool baffles and a drain back to your sump.
Oil vapour = lower octane of your fuel and grime up intake. Which we all know is an issue on VQ motors. When I ripped off my intake it looked like someone had poured a bottle of oil through the intake. (Given it probably had never been pulled off its whole life of 200,000km)
Yeh, i'll probably do that, or just get a silicone joiner the same as the black pipe, just a little more dollars.
Edited by JayM35
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
