You may find that once it it being controlled by the ecu, it actually pulls closed. Most throttle bodies have an air bypass port to control idle, and the butterfly seals completely.
Not this Throttle Body Dale. This one has no bypass.
This is why you have to clean them on a occasional basis or the car can start to stall.
Cheers
Andy
Cheers
Andy
Definitely explains the reason. A small amount of blockage would cause issues.
You learn something every day pinch.gif .
yeah spoolin has 19x9.5 +40 with a 12mm spacer so effectively a +28 offset... but they do stick out a bit - he has stretched tyres and they dont scrub.
but talk to him about tyre wear. with that width and offset you cant take out much of the camber or they will scrub the guards, so tyres wont last long.
Cheers mate, shot him through a PM.
I'm also looking to stretch so hopefully it won't rub too much.
Would a narrower rim help at all? The only reason I ask is the rims I'm looking at only come in +22, 10 or 0.
A narrower rim will always help. As I mentioned I am running 19x8.5 +22 and thats pretty flush.
You can work out how much more they will come out with the following equation:
(width (in inches) x 25.4(mm)) Divided / by 2 - the offset is how much rim comes out from the hub face
So mine that are flush are 8.5x45.5 = 215. Divided by 2 = 107.95. Minus the +22 offset = 85.95mm from the hub face. And thats about flush with the front guards: see pic below.
So 9.5 +22 would be 98.65mm from the guard. So it will stick out a further 12.7mm than what I have.
Ben.
Edited by bbenny
Ben.
That is a really good fitment...
Ben.
That looks perfect
I'm looking at something like this:
Yeah they would look awesome! Ce28 copy? are they Vaerrston or whatever the brand is called?
I should also mention if you run 9.5 you cannot run an offset higher than +35 or they will rub the front suspension arm.
Will look awesome!
I'm thinking of getting new wheels, I love my wheels but they're just a little too small. 18x9.5 at +15. I'll see how it looks once it's slammed with 25mm spacers.. So -10 lol
They are indeed.
So really my only option is the 9.5 to get a few tyre options and the highest offset these come in is +22 so rubbing on the suspension won't be an issue. I will do some ringing around RE 19in tyres to suit an 8.5 as if I can find some at a reasonable price I'll go that way.
They are indeed.
I think you said you were in Adelaide? Call Mark at SA Motorsport Tyres on 0409288380, tell him Ryan from Pure Motorsport sent you. He'll look after you.
Removed the Walbro fuel pump today and reinstalled the stock fuel pump and fixed my big hesitation problem around right hand corners ... :)
No issues supplying enough fuel with the stock pump?
It was well and truly maxed by 220, as the pressure dropped after that point and the injectors had to be opened exponentially to squeeze more flow out of it. Not where you want to be, fuel supply wise especially if you have stock injectors.
I may put the Walbro back in but need to do 2 things first,
1) use the filter fitted to the stock to the pump. (I think the filter fitted to the Walbro may be part of the problem. It is smaller and in less than 12 months has gone black)
2) Run the 12v power supply to the pump. I agree that the Walbro seems to perform better with the additional power.
Especially as I have the 60lb Siemans injectors to go in with the tune.
Went a bit overboard on eBay today, picked up my slimline fan ready for the front mount intercooler, and ended up getting a Nismo dash after putting in an offer... Bit sad, but ah well!
Do you have the factory Screen/Nav Unit. I saw the cluster on ebay also, but was trying to determine if it was the right cluster to suit car with factory screen (different part numbers according to Nismo catalog)?
I have a set of Nismo boost gauges. Looking for the Nismo cluster as we speak (ex Japan). Out of interest, what did you end out paying?
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
