yeah where the oil filter adaptor bolts to the motor? has oil lines coming out of it to go to the turbo.
if water goes in there, i dont think its to cool the oil. the oil is generally cooler than water. maybe its to warm the oil up faster?
perhaps..
although the oil line for the turbo comes straight from the oil sump. lol
anyway i think the o-rings shit itself.
The water jacket heats the oil quickly up to operating temps, specifically the oil being pumped around the engine. It just means you can get on the gas quicker but is still takes twice the time generally to heat the oil. After this point its just backup cooling if the oil ever heats to over 90 degrees. There is a special orange oring behind the water block thats leaking on Aarons, he could have just siliconed it up but I suggested a new seal, mainly because I don't like silicone in the oil pathways if you can help it.
but its primary job is to heat the oil. and IF the oil overheats, then it will cool it. assuming your primary cooling system is doing its job well :P
ok you've lost me.. whats the primary cooling system??
the radiator and fan(s)
the oil lubricates the engine, but it does store heat too
Mmm, I think oil cools an engine more than most people think. I had a V8 when I was a lad that had a chronic overheating problem (one hard acceleration run would have it steaming) so I put an oil cooler on the engine. In winter I had to tape cardboard to the front otherwise the needle wouldn't move off cold & the heater wouldn't work lol. I reckon I could've run it without water, with just the oil cooler doing the job.
The proper term would be a heat exchanger just like the one in radiator for the auto trans fluid ...which also serves to bring the auto trans up to operating temp more quickly but also has some cooling function if the auto trans fluid gets too hot.
Finally removed the standard intake today. Bottom nut caused me all sorts of grief (typical for me unfortunately) by getting all round. Had to grind a slot in it using a Dremel with a flexible shaft to get up in there. A good hit with a hammer & screwdriver had it off in the end. I think I've spent more money on buying tools to remove the nut then I have on the materials to build the entire intake lol.
Its a pain in the arse to get up under there. Did you snap the stud off in the end?
No, the stud is intact & undamaged. Probably more from good luck than a well implemented plan LOL. I just ground a slot/vee most of the way through one face. The hammer/screwdriver combo spread the nut enough to loosen it & it came off without the use of tools.
However, the sexy & well engineered funnel & flange you made for me looks like it is too long to get any sort of bend before hitting the cross member. I'm going to hunt for some tighter bends (silicon & aluminium) tomorrow & have a rethink. I may have to make up something closer to what you've been doing all along.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
