Damn..... Is that the reason I have shut arrive that I don't remember buying!!!!
Haha so dangerous...
But, while completely sober, I just scored myself an Emanage Ultimate! :banana:
Despite some sniper at the end who drove the price up from $150, scored it for $355! Came off an R33 and he has an SR20 map, but I should be fine to hook it up. Plus it seems to come with a universal loom! :banana:
I'm very happy with that catch, can't wait to get it hooked up. Just have to get the boost sensor, and should be right to go! Might even try and get it tuned by Cian when I come over for Gymkhana if time allows.
fitted up my 3" bellmouth front dump pipe this arvo, the car pulls sooo much better.
Just gotta get a 3" metal cat and the car will be 3" from the turbo to the rear blast pipes
sooo much less restrictive, and i made it stealthy black :ph34r:
Just fitted my shiny new bc coilovers yesterday, they are a pretty good piece of gear. I did get a bit excited about dropping it though, ended up running about -5 degrees of camber on the rear this resulted in my 350z wheels touching the shock body.fixed it all up today and it feels like a new car. I will say that one of the factory shocks died at the hands of my 4 inch grinder because it wouldn't come out easily - no pain no gain
....And the flames???
they are a bit bigger, turbo spool is alot faster and a lot louder.
but the flames are still there, i nearly melted one of the lads at works R32 front bumper twith them over the weekend!
so he kept up with you :nyaanyaa:lol joke.
dump/front looks great!
found out i have a nice fuel leak from the o-ring seal.
figured out when i lost a quarter of the tank within about a minute and 2kms lol
will need a part number if anyone has it.
cammmm.
Went for a retune on Sat with the MAP sensor and EBC installed...
made an extra 6 awkw @ 19PSI...>_<
The good (or bad) news on the other hand was that Cihan found the LPG was leaning out above 5k rpm...not sure why this was happening. Possibly the weather as the last tune was done in March.
So at least now I won't unknowningly blow my engine up while on gas...:blush:
need bigger jets...guess this will stop me from procrastinating from taking my car back to the gas joint.
Got a price for me for the GTX setup yet Scotty? :whistling: Can't believe I'm such a number chaser...lol
why the GTX?????
arghhhhhhhhhhhhh
you can't compare torque figures from rolling road dynos
its tractive effort which is a factor of wheel size, tyre profile, gear ratios, diff ratios and lots of other stuff
only true way to get a torque reading is on an engine dyno
i know that, but i wanted to see if there was a difference from this time compared to his last tune. i dont care what type of effort it is, if there is an improvement, regardless it will show.
arghhhhhhhhhhhhh
Well considering all these cars use the same gear ratios and diff ratios, and rolling diameters will be very close; it's probably a fair comparison, especially given they're all on the same dyno.
Everyone knows it's just a number; but with identical drivetrains you're comparing apples with apples...
nope, ARX and AXIS have a larger rolling diameter.
also PM35s are different, also as as 2WD and 4WD models of the PM35 (im only talking about models available in australia)
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
