lol that would be more likely!
We're taking 4 total. Guys in the back were complaining they couldn't watch DVDs, and for the cost of these headrests I figured it was worthwhile.
Robbie has 5 going over I think, want to hope it's not all in the one car. I know he's taking a Caprice over instead of the Stag.
I've got 6 coming, 4 in the caprice, 2 in either an rx8 or a b2200 ute running a 13b turbs.
It's only costing me $20 a day to have the leathered out, DVD playing, spacious 6 liter caprice, so I figure why not, use someone else tyres and spend alot less in fuel too.
I have a better story... the two headrest monitors I ordered on eBay Sunday turned up today... FROM HONG KONG! :worship:
They look great, two 9" monitors with zip up covers to hide them from prying eyes. Can't wait till Brad and I get them installed Sunday.
Which ones did you get?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=280608148792&ssPageName=STRK:MEWNX:IT
Made an offer of $200, which was accepted almost straight away. You can get cheaper ones, but I didn't want vinyl headrests to go with my cloth seats :wacko:
http://cgi.ebay.com....e=STRK:MEWNX:IT
nice work ryan, thats really cheap! i was after an independant one that you can put a DVD into. the standard facia i have kind of restricts me here lol
IMO... I would not do the DVD head rest again but just use a hard drive or Ipod/Iphone for movies.
The DVD plays are good to start but 2 years on my son complains about the disc jumping on less than smooth roads.
Cheers
Andy
Cheers
Andy
didnt think of that. i guess with the AV inputs you can basically plug anything into it.
X100. Digital media FTW...I can't remember using optical media for a while now...apart from ripping stuff...
yeah same. i dont even use optical media in my computers. im thinking of replacing my optical drive in my laptops with a 2nd hard drive bay. or maybe another battery!
back ON topic. the exhaust is settling in. the ECU runs rich for a few seconds after backing off and now it pops when the exhaust is hot :)
Did anyone with an intake notice that they ran particularly rich when backing off? Before the e-manage tune of course.
I've tuned mine so the AFR's are good at light to medium loads (runs really nice actually), but when I lift off after accelerating, the AFR's start to go lean (as they should when coasting) but then go full rich (10:1 on my display) for a few seconds which causes a heap of smoke out the back.
I can post pics of log graphs if it will help, but it really just displays what I said (I hope :blush: ). I'm thinking of returning the intake to stock to confirm the problem goes away and then get some graphs to compare with the new ones, but that will require some work...
As an aside, I don't know if anyone else has seen this, but it appears to me that the standard ECU has another map that it refers to after a certain rate of acceleration (or throttle application) occurs. I found this out because my AFRs remained essentially unchanged at the top end regardless of what I did to the AFM signal at those load points. It is like it ignores the AFM signal & does it's own thing.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
