sorry for my ranting earlier, i was rather pissed off and the tuner will never answer their phone and i have some other issues so i took it out on here so SORRY EVERYONE.
edit, its running a high pressure actuator, that run is without a boost control as far as i know.
Edited by lilcrash
R35 GTR seats fitted! Sitting much lower than my factory seats! Need to raise the passenger seat a touch. Loving how factory they look.
Boost controller/emanage in and tuned. Having the same issue as lillcrash. Spiking at 18psi and dropping to 14psi. Need a tougher spring. Car drives much much better though. Less lag, much more mid and a bit more up top.
lol..... :whistling: you do need to raise that passenger seat a tad.. felt l I was sitting on the floor.. also never had trouble seeing over the dash before.. lol
Yes, it does feel good.
yeah, horrible boost drop off there...try and get that fixed before being too concerned.
I'd start by running the car again with no exhaust, and see what the result is. Also, have a look at the intake under the bonnet when it is at full boost for anything sucking shut, stock rubber parts in particular
Finished putting my freshly painted d pillar panels and mirrors on, removed the factory rust from behind the mirrors. More rust than I expected but minor compared to some I've seen
If the exhaust Is the restriction it will always be there. It's too loud without an exhaust. Mayb the k&n is too restrctive
installed my shift kit today. definite improvement! also fixed the leak in the trans cooler pipework
helped craig swap his gearbox!
and managed to buy a nismo ecu on yahoo.
not bad for a days work!
Lol, how good is the shift kit?:thumbsup:
More awesome? You already had one, right?
Took mine for a burn up the old pacific hwy today with a mate in a 180SX.
Glad I moved the fnt sway bar to the maximum slot, much better handling. Was fun driving a SR20 for a bit (would make great track/weekend hack), but swapping cars, I defiantly saw 15 years of improvements/refinements/abuse
Bought a few car detailing things and ordered a transcooler too!
Winning!
Edited by PN-Mad
one item of awesome will be up for sale yes
as for the shift kit, for a few bits of metal and a few springs, its a massive improvement lol
Dibs! Send me a pm if/when its for sale!
Winning!
Which trans cooler did you go for?
Love the fact that now you are only apportioning "Awesome" to worthy cars/owners...happy.gif
Edit - PWR 280x150 just getting it ordered from repco... they can order in any PWR stuff. Should be good enough, plus I don't fleabay.
Edited by PN-Mad
If he keeps buying all the 'awesome' before anyone else gets it, then he can be the gatekeeper! :worship:
Nice one on the trans cooler. Didn't think of that, was going to order B&M online. I'll go see them tomorrow. Does yours have a thermostat?
Lol...
It doesn't have a internal thermostat- I'll be getting one off Jetwreck that goes in line and does the job. PM him if interested...
there will be a post lol
maybe ill ebay it. not sure yet!
is it just me or after the shift kit install, the transmission appears to 'slip' less even on take off? im guessing this may assist with fuel economy
That cooler is plenty big enough, I like the look of those little thermostats; full flow in bypass.
I'm a little dubious about the way the b&m coolers use oil viscosity as a measure of temp for the bypass.
