Speaking of which, do you think its worth adding a fine inline filter for the trans cooler?
Could be but it does have 2 large magnets + a large fine filter and 4 small ones......one would think that that would be enough to get rid of most of the crap. In saying that I have had a couple of gearbox's with so much crap on the magnets that they looked like Donut's but all of those gearbox's were driven across the gate most of the time....funny enough my old crapped out gearbox was pretty clean throughout!
One of the main things I do when I do these kits is make sure that all the components a free of all crap and very clean before the VB goes back in!
1. New Radiator due to leak in top tank (nothing special - just Koyo aftermarket OEM style but for $240 delivered and no modifications required it was a good fix to get me back on the road).
2. Oil Change
3. New tyres on the rear today due to camber wear....
Temporarily fixed rattling side skirt brackets, seems grey tape isn't enough though.
Hate the idea of tek screwing my sills.
Slackarse bodykit fitter, not attaching them properly (was on it when I bought it).
The brackets don't line up with the inserts already fitted to my sills.
Sika may have to be employed........
Finally ordered a trans cooler, the same B & M with thermostat that jasevr4 is running. Will get it in with the shift kit, hopefully before the end of the year
I bought the PWR heavy duty V8 trans cooler kit from Repco. Was $130 but during November it's 20% off with an RAA card. I used a work mates card :) so only $103.
Edited by slippylotion
Yeah I was going to go that way, but knowing that the B & M would fit with the HDI intercooler was a bit of a comfort.
Worked out the same price, and has a thermostat built in, so all good! :thumbsup:
removed all the un used stereo wirring that ran to the back of the car which was left in there from japan!
also pulled out my fuel pump to check if it has been upgraded from the standard R33 GTR item, Unfortunately it hasn't been.
need to sell it to upgrade to 040 or nismo
i'd get the deatschwerks fuel pump
http://www.ebay.com.au/itm/DeatschWerks-300-LPH-Fuel-Pump-In-Tank-w-Install-Kit-Similar-GSS342-NEW-/310350325524?pt=Motors_Car_Truck_Parts_Accessories&hash=item4842522714
same size as stock, 300lph and cheaper than an 040
replaced both front swaybar links, and bushes, and tinted my front windows :banana:
As a matter of interest; what was the cost of the front links? Did you replace both pieces? Can you add the part number to the M35 Info thread?thanks.gif
Slippy: Tint didn't cost me anything (mates rates), complete windscreens on main north road, 35% as i want to keep it legalish (my privacy glass has tint on it aswell [not legal]). Tell them I I told you to come in and they'll do you a deal.
Daleo: The swaybar links ("rod stabelizer and connecting stabelizer" is what it says on my invoice) were replaced under warranty with no part numbers on the invoice (from japan they took 2 weeks). My mate works in parts for nissan and he got me the part numbers though......
RH= 54618-aq300
LH= 54668-aq300 both ex japan 10-15 days
Edited by MOUTH
Don't use the tierod ends I posted up
Taper is too small (I was finally able to compare them back to back with stock ones)
The hunt continues today...
A busy weekend on the M35...a full set of QFM HPX pads went in, as well as an oil change and filter. All the Swaybar fixings were checked and tyres rotated, and last night I cleaned out everything that could rattle, move or slide in preparation for a track day on Thursday at Mallala.
The forecast says maybe 5-10mm of rain...mine will be the only 4WD out there so I'm hoping it's right!
Ryan, did you ever make it out there in yours? Have any other M35s got a lap time I can aim for?
I didn't make it out, I had to work. Not sure if Dunc has a time you can aim for?
Good luck! Let us know how you go and make sure you have lots of pics!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
