Speaking of which, do you think its worth adding a fine inline filter for the trans cooler?
Could be but it does have 2 large magnets + a large fine filter and 4 small ones......one would think that that would be enough to get rid of most of the crap. In saying that I have had a couple of gearbox's with so much crap on the magnets that they looked like Donut's but all of those gearbox's were driven across the gate most of the time....funny enough my old crapped out gearbox was pretty clean throughout!
One of the main things I do when I do these kits is make sure that all the components a free of all crap and very clean before the VB goes back in!
1. New Radiator due to leak in top tank (nothing special - just Koyo aftermarket OEM style but for $240 delivered and no modifications required it was a good fix to get me back on the road).
2. Oil Change
3. New tyres on the rear today due to camber wear....
Temporarily fixed rattling side skirt brackets, seems grey tape isn't enough though.
Hate the idea of tek screwing my sills.
Slackarse bodykit fitter, not attaching them properly (was on it when I bought it).
The brackets don't line up with the inserts already fitted to my sills.
Sika may have to be employed........
Finally ordered a trans cooler, the same B & M with thermostat that jasevr4 is running. Will get it in with the shift kit, hopefully before the end of the year
I bought the PWR heavy duty V8 trans cooler kit from Repco. Was $130 but during November it's 20% off with an RAA card. I used a work mates card :) so only $103.
Edited by slippylotion
Yeah I was going to go that way, but knowing that the B & M would fit with the HDI intercooler was a bit of a comfort.
Worked out the same price, and has a thermostat built in, so all good! :thumbsup:
removed all the un used stereo wirring that ran to the back of the car which was left in there from japan!
also pulled out my fuel pump to check if it has been upgraded from the standard R33 GTR item, Unfortunately it hasn't been.
need to sell it to upgrade to 040 or nismo
i'd get the deatschwerks fuel pump
http://www.ebay.com.au/itm/DeatschWerks-300-LPH-Fuel-Pump-In-Tank-w-Install-Kit-Similar-GSS342-NEW-/310350325524?pt=Motors_Car_Truck_Parts_Accessories&hash=item4842522714
same size as stock, 300lph and cheaper than an 040
replaced both front swaybar links, and bushes, and tinted my front windows :banana:
As a matter of interest; what was the cost of the front links? Did you replace both pieces? Can you add the part number to the M35 Info thread?thanks.gif
Slippy: Tint didn't cost me anything (mates rates), complete windscreens on main north road, 35% as i want to keep it legalish (my privacy glass has tint on it aswell [not legal]). Tell them I I told you to come in and they'll do you a deal.
Daleo: The swaybar links ("rod stabelizer and connecting stabelizer" is what it says on my invoice) were replaced under warranty with no part numbers on the invoice (from japan they took 2 weeks). My mate works in parts for nissan and he got me the part numbers though......
RH= 54618-aq300
LH= 54668-aq300 both ex japan 10-15 days
Edited by MOUTH
Don't use the tierod ends I posted up
Taper is too small (I was finally able to compare them back to back with stock ones)
The hunt continues today...
A busy weekend on the M35...a full set of QFM HPX pads went in, as well as an oil change and filter. All the Swaybar fixings were checked and tyres rotated, and last night I cleaned out everything that could rattle, move or slide in preparation for a track day on Thursday at Mallala.
The forecast says maybe 5-10mm of rain...mine will be the only 4WD out there so I'm hoping it's right!
Ryan, did you ever make it out there in yours? Have any other M35s got a lap time I can aim for?
I didn't make it out, I had to work. Not sure if Dunc has a time you can aim for?
Good luck! Let us know how you go and make sure you have lots of pics!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
