Is it on yet? What wheels did you end up with?
Yes, fired it up last night to check for leaks. Only one was exhaust, but was last join in the cat back so easy to fix. I still have to drop the radiator fluid as only put water in it for the test in case it was a total fail & I lost all the green stuff. Still haven't driven it.
No idea what wheels went in. I wasn't asked what I wanted when I ordered it & didn't know I had a choice. Probably a good thing as I would have researched it to death & then chosen wrong, lol. I just hope it's not too laggy.
Not planning to go through all that again I assume? lol.
I suspect he put the smaller wheels in yours, did you take any pics? We should start a Stagea Hypergear thread and post pics up with power/lag results. I took quite a few...
my wheels r pretty big i mean its laggy but not all that bad , it does come on friggin hard though i think youll be happy with it, especially after a tune itl make such a difference
When does it come on boost? When does it hit max boost?
Is the bigger Hypergear core more expensive and laggy compared to Leon's?
The billet compressor is $200 more, the customer can decide how laggy they want it to be...
It seems to be around 3500 from what I saw, perhaps you can elaborate Marko? Bit hard without a boost gauge I suppose.
I think the sizes are teh ghey. Their staggered for a start, and I think the fronts run a really high offset? like +47 or something?
Yep. Fronts are +47 I think and rears are +15. I thought about getting 2 sets and run the +15s only but too much hassle.
That's pretty good...your old/my setup hits max boost around the same rpm? so its not too laggy then...
Its not laggy at all for the power, just when you compare it to the stock turbo.
Im going back to edge tomorrow for my attempt to crack 350kw with the GTX3071, will let you know how it goes. I wouldn't like to go laggier than what I have at the moment but where is the fun in stopping there? Next goal will be 400. :)
Haha, no Scotty, not planning to do that again in a hurry.
I took quite a few pics and, because I had my original turbo plus the hi-flowed one, I was able to do side-by-side photos. Makes it easy to see the difference.
Good idea re new thread. It's started so you & Marko can make the first posts with your results. I still have some info to gather before having anything useful to post.
Sprayed up the front bar with a can for the trail fit.....also fitted the rear bar up.
Just waiting on the new rear wing now and then it's time for the spray jobs.
I also fitted a new pre-load spring to the Actuator.....back to 14PSI+ launch's! :P
Looking very mean! When the flairs merge in it'll be spot on. Its a shame the former owner of that front bar decided to cut out the stock Kenstyle/Xanadu style grill. Irrespective, it's looking good. Whats the height from ground to the front lip?
so I finished the test fit up of the front and rear bars today....looks OK imo! Just need to get the rear wing and maybe a vented bonnet on and the outside is done!!!
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
