Is it on yet? What wheels did you end up with?
Yes, fired it up last night to check for leaks. Only one was exhaust, but was last join in the cat back so easy to fix. I still have to drop the radiator fluid as only put water in it for the test in case it was a total fail & I lost all the green stuff. Still haven't driven it.
No idea what wheels went in. I wasn't asked what I wanted when I ordered it & didn't know I had a choice. Probably a good thing as I would have researched it to death & then chosen wrong, lol. I just hope it's not too laggy.
Not planning to go through all that again I assume? lol.
I suspect he put the smaller wheels in yours, did you take any pics? We should start a Stagea Hypergear thread and post pics up with power/lag results. I took quite a few...
my wheels r pretty big i mean its laggy but not all that bad , it does come on friggin hard though i think youll be happy with it, especially after a tune itl make such a difference
When does it come on boost? When does it hit max boost?
Is the bigger Hypergear core more expensive and laggy compared to Leon's?
The billet compressor is $200 more, the customer can decide how laggy they want it to be...
It seems to be around 3500 from what I saw, perhaps you can elaborate Marko? Bit hard without a boost gauge I suppose.
I think the sizes are teh ghey. Their staggered for a start, and I think the fronts run a really high offset? like +47 or something?
Yep. Fronts are +47 I think and rears are +15. I thought about getting 2 sets and run the +15s only but too much hassle.
That's pretty good...your old/my setup hits max boost around the same rpm? so its not too laggy then...
Its not laggy at all for the power, just when you compare it to the stock turbo.
Im going back to edge tomorrow for my attempt to crack 350kw with the GTX3071, will let you know how it goes. I wouldn't like to go laggier than what I have at the moment but where is the fun in stopping there? Next goal will be 400. :)
Haha, no Scotty, not planning to do that again in a hurry.
I took quite a few pics and, because I had my original turbo plus the hi-flowed one, I was able to do side-by-side photos. Makes it easy to see the difference.
Good idea re new thread. It's started so you & Marko can make the first posts with your results. I still have some info to gather before having anything useful to post.
Sprayed up the front bar with a can for the trail fit.....also fitted the rear bar up.
Just waiting on the new rear wing now and then it's time for the spray jobs.
I also fitted a new pre-load spring to the Actuator.....back to 14PSI+ launch's! :P
Looking very mean! When the flairs merge in it'll be spot on. Its a shame the former owner of that front bar decided to cut out the stock Kenstyle/Xanadu style grill. Irrespective, it's looking good. Whats the height from ground to the front lip?
so I finished the test fit up of the front and rear bars today....looks OK imo! Just need to get the rear wing and maybe a vented bonnet on and the outside is done!!!
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
