I wouldn't bother mate. If you are dead serious about power, then get a different (3inch) muffler welded on the end and keep that Muffler. But I would suggest if you don't have a high flow turbo, piggyback, etc etc, I don't think the exhaust will be that big a deal. I'm only going by the Mods in your Sig. Do you really want it louder? Doesn't seem like it has any muffler to it anyway!
Fitted Tein S-Tech springs in my series 2 RS4S yesterday. Was hoping for the 1.5inch drop that they claim but it's only dropped about 10mm in the front and practically nothing in the rear. Just hoping it'll settle down a bit over the next couple of weeks with driving. It's definitely stiffer though.
Went to drive it for the first time in 2-3 weeks, found the battery was flat.
Put it on charge for about 6 hours, checked voltage, 1.5v. Pulling it out and putting it on a deep charge for a couple of days to see if it'll be ok, since it's only about 6-9 months old. :(
just fitted a new rack end on passenger side, bought a new pair from ebay (link from Dale)
http://www.ebay.com....#ht_1749wt_1037
after fitting it and drove the car, steering was very loose that when i came out to check the wheels. the left one (passenger side) had a toe in about 5-7 degrees :angry:
after a closer inspection, the new rack end is actually longer than stock one (refer pic) so had to cut off to roughly the same length, now just need to do wheel alignment
thought to share this so if anyone else needs to change the rack end to the same ones i bought, better measure and cut 1st
I had to remove those two black strips at the edges of the tailgate lid & the spolier screws into the metal beneath where they sat.
Then it just basically sits on top of the black plastic trim that the centre brake light is part of (with help from a bit of double sided tape)
I'll take some more pics when my wife gets back from the shops with it. :whistling:
Dyno'd the car last night. Car feels awesome to drive. Less boost made more power.....18.5psi ftw!
240killa wasps....car feels strong right through the range.
Jez the tune is awesome....and the f$@ker starts hot or cold for the first time in a long time.
Excellent buddy :) glad ur happy.
Sorry about the dyno sheet. Damn dyno restarting on me. Forgot to input ur details back in correctly.
Haha i underestimated ur car. Wheelspin on the 1st pull of the night. Was exciting. We need to find a way to lock it into gear though. Was hard to tune below 4000rpm. Will have a play on the road when u are ready
Limp mate, the kickdown is just to keep you on your toes. :P
The torque converter lockup solenoid needs a 12v voltage on it for a start...
I made up some speaker mounts for the M35 to fit some Alpine Type R 6.5" front splits and 6.5" rear 2 way coaxial speakers. Made them out of some structural ply I had laying around. These will finish up with the speaker sitting close up to the door trim as the factory speakers do. Will finish them up and install them over the next few days. Pretty happy with the result so far.
Edited by slippylotion
Haha sure did. Foot flat 100rpm too early and it
Jumps down a gear.
With the lock up how well does this work? It would be good to do this just whilst tuning then we can put back to standard
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
