Most likely you've ended up with a reasonably bad boost leak....do you have a boost gauge, and if so what does it show.
Go back around the whole job and check every hose is seated square, and every hose clamp is tight. The easy way to check a hose clamp is to push hard on the screw part - if it turns on the pipe it is too loose. But even if they are tight, the hoses have to be properly seated on the pipes, ie square on and good overlap
Howdy,
thanks for all your input!
I Double checked the hoses and een had a mate of mine come by after I had installed it yesterday to ensure everything had been connected properly. No problem.
I spent all day wiring up a boost guage (Apexi mechanical) and finally got it to work.
on idle: -0.5 to -0.6
driving: -0.7
OK, so im assuming it should be idling on 0?
Howdy,
driving: -0.7
No, that sounds reasonably normal. Engines are almost always on vacuum (ie less than 0) because they suck air in. the more you open the throttle the more air they suck so the more vacuum you'll see. But with a turbo car of course, as it comes on boost it moves from vacuum (negative) to boooost (positive), but only when the engine is under load.
Unfortunately that means that you need someone to watch the boost guage while you floor it for a while. Up a hill is best because boost builsd more quickly and the car accelerates more slowly.
OK so took it for a drive today and found a steady incline.
During acceleration, the gauge hovered around 0.5 and whilst in 2nd gear at around 3000rpm onwards I could feel the car 'stuttering'.
Thoughts? I think this is getting a bit too over my head for me.
Finished stripping the heads off today and cleaned up the block ready for the new oem head gaskets and L19 studs. It all looks pretty clean in there now, hopefully an oil flush will clean out any residual coolant I haven't managed to get to.
Luckily it looks like just a split head gasket...
Today, i pulled the glovebox apart to investigate what sorts of plug connectors the DVD rom's got, and found the glovebox light was blown. Replaced the bulb, all good now. Also cleaned the pollen filter. Still not able to get the reversing camera wired up as the camera wont work for some reason(ntsc). Also gave it a wash. :yes:
Gotta love how E85 keeps the pistons and combustion chambers clean.
Is that the knock sensor in the valley?
yeh i asked him if it was yesterday and yeh apparently it is the knock sensor
What's this Aaron? A non random post? That's not like you...
Yeh Paul, the pistons were only a little coated in carbon, a light spray with gasket stripper had them polished like new.
And yes, that is the knock sensor, not that the Fcon cares about it much.
In Pic 1 is that a cast mark on the engine mount or a crack ?
could the issues that I have been experiencing be a coilpack issue? I remember experiencing something similar with another car of mine years ago..
Just a casting mark.
It sounds like it, Stuttering is usually either plugs that are fouled or coil packs breaking down. It could also be low voltage/bad connection in the coil loom. Without more information about the car's mods and power level its hard to guess the cause.
Studs turned up today, all went in well bar one, it looks like the thread is a little chewed. :verymad: I will have to buy a long M11 x 1.25 tap tomorrow.
I also match ported the upper and lower plenum halves and throttle, the head ports looked pretty good but the runners were all over the place.
Nope. lol, I don't trust myself around the valves without removing them and I don't want to get a stray piece of alloy in the oil galleries. Do you think it matters? The area of the 6 ports is a crapload bigger than the turbo and wastegate. It should be fine mate. There is definitely a heap of material I could remove there though.
im gonna talk you into it lol..
i think you should.. why not its all apart.. just be a true hampton parker and shove a sock down there and vacuum it out before you take the sock out lol
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
