Finally fitted the new wheels and tyres!
The old ones were a bit knackered...
Although perhaps I could reuse them as semis?
New tyres are Hankook Ventus R-S3 245/40R18 XL, so they have a higher load rating.
Mounted on some new Braid Winrace A 18x8 +30s...
Front:
Rear:
The offset isn't too bad in the end:
post-34363-0-71778600-1339830557_thumb.jpg post-34363-0-67935300-1339830570_thumb.jpg
Also put on Volk Formula nuts, which seem to look good in combination.
All in all, pretty happy, and they're much nicer to drive!
Big thanks to SA Motorsport Tyres for a great deal, and a lot of help putting it all together. Looking forward to the next track day!
More pictures tomorrow after Moby has had a wash!
Looks the goods mate. If I were you, I'd find something a good detailer would recommend as a paint sealer or similar product, and get it on them right away. Will help get the grot off. There are some not so good products out I've heard, so consult a good detailer.
The old jap playz tyres hey, good for skids!
Thanks guys. Yeah the offset worked out well in the end. And they do look a lot like an old school race/rally wheel, which I like :D
I'm heading down to Autobarn tomorrow to get some proper wheel cleaning gear. The QFM pads are pretty low dust until you get to the track. Then the fronts just caked the wheels, backs not quite so bad. Dad has some great Wurth gear that you just spray on and soak in, then hit it with the hose (with some pressure).
Haven't heard of sealing them before, I'll look into it, thanks Alex.
Looks the goods there Ryan, you're running the same offset as mine, with a slightly smaller rolling diameter.
Regarding Wheel sealing; I definitely recommend it, I've been using Autoglym Wheel Seal for several years now; it's just an aerosol spray on; wipe off deal.
I re-apply it every few months, and the brake dust just washes away with a Meguiars wheel detailing brush.
I'd stay away from anything you need to leave soaking; they should clean up with minimal effort once sealed.
Less "What I have done" and more "What Alex has done".
Dropped off his Chassis Brace last night, and Alex kindly offered to throw his laptop & Cypher diagnostic on my Stag, to check for any outstanding ECU and SRS fault codes.
None found; which was not unexpected, as my Attessa works fine, and I don't get any random Airbag codes.
He then offered to throw 2 degrees (from a possible 3 deg advance in my case) of base timing in, and see what I thought of it. TBH, I wasn't really expecting much; but Alex told me a few interesting things about the improvement on another Forum members car.
A quick run up the street to ensure there was no knock; all good.
The trip home revealed a surprising result. The car is more responsive at small throttle openings, and seems to come on boost a little harder too. It's hard to explain; but it just feels a bit "tighter", like a bit (more) of the slack has been taken out of the throttle. Also it's less inclined to kick down on a hill in top gear, on the cruise control, which suggests that there's a bit of extra torque; just as Alex suggested
It's another little "1%" improvement, that our cars seem to have plenty of...
I'm quite impressed that such a small change could net such a pronounced improvement. I'll be giving it a bit during the week and if all is well; I think I'll be asking Alex to try the last degree at the Stagea meet.
Thanks again mate; when we were talking beers, I was honestly expecting a sixpack; not a whole case! :woot: I'll still drink them though...
Also pressed in a new set of Whiteline Lower Control Arm bushes, ready for my new brake set up this week.
Yer he did the same to mine, I find it's just a bit more responsive than normal, just a tad which helps with the shift kit:)
Yours was the car I was referring to Rudi; did you go 2 degrees or 3?
Every time I have a little tinker; I find myself wanting to spend buckets of money...
Dale, I'm glad your happy with it!
No worries about the beers - thanks for getting me out of that sticky situation.
Very happy mate. :yes: Bring your laptop next weekend please? I think I'd like to try that last degree.
Any time mate; happy to help out. Drilling holes in other peoples stuff, while partially drunk is my speciality...
Cheers Dale. Never sealed wheels, so I'll head down and see what I can get. Good call with the brush too, getting between those spokes could be a pain.
The Wurth stuff does a great job, never had any issues with it, but I'll probably give the Bowden's Own wheel clean a go. Really happy with the rest of their stuff, and have alook at that Autoglym sealer.
Good to hear the timing works. Keen on going an extra degree?
I put mine on a truck a few weeks ago and had it safely arrive in Perth on Friday.
I had a search but turned up donuts, can anyone recommend anyone to go to in perth, preferably the nth side to look after it? If they can do a vehicle safety check (pink slip) that'd be great too!
Now just waiting for my Apexi N1 from joshm35 to arrive :P
Edited by NickM91
Yeah, there's no sign of pinging that I can hear, so I figure if it goes well during the week; why not?
He did 2 degrees from memory. It was worth the try I think :)
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
