Very happy mate. :yes: Bring your laptop next weekend please? I think I'd like to try that last degree.
Any time mate; happy to help out. Drilling holes in other peoples stuff, while partially drunk is my speciality...
What!!!!!!
I have taught you well! ;)
Ian, new front bumper looks heaps better!
Thanks Ryan.
I'm in the process of making the blanking plates to fit the LED indicators. I've posted the progress so far in the Fabrication section.
link is here => http://www.skylinesaustralia.com/forums/topic/402693-indicator-blanking-plates-for-aftermarket-front-bar/
Lol. Yes, yes it is.
Try failing to get the thermostat on correctly, filling it with coolant only to have it pour out all over the floor. Then pulling it all apart again to fix. Derp. Amateur hour.
How did you go with the trimming?
ohh yeah the radiator. damn its big, if you overheat with that ill be surprised!
Yep; she's big bugger!
Yes it is.....funny though! Trim....then trim....then trim......ect.
Thank goodness it's not metal though! ;)
Fortunately, I had a hoist, die grinder and air hacksaw in my arsenal today; needed all of them. :yes:
I'm not completely finished, I'll be making a new set of top mounts; doesn't fit the OEM top positions. Bottom end was nice once I'd done some trimming.
Drift Spec cable tie top mounts ATM. :whistling:
Also sent my R34 rotors out for slotting today, and had my current front rotors skimmed as I've recently picked up a bit of a shudder. My new set up looks like being ready to go on in a week or so.
Edited by Daleo
I bought Iain's China Rad, that was then modified to be a bit more of a direct fit. The trans cooler loop & fittings were nice too.
Which it was, but yeah it was a bit of an ordeal.
A little bit more neatening up, and I'll be happy. Just got to push the airbox lid in a bit with a heat gun and I'll be sweet.
Possibly one more bleed/top up, but I think I've got it sussed now.
Yes, they are. You can nail it in one go, but sometimes it will take you a good few trys. Nothing overly hard about it- open heater core, use the rear bleed, but sometimes it is just easier than others
Nice. I haven't looked into it yet, are these things a pain in the neck to bleed the cooling system too?
Not really, but I used a little tube & a funnel to get a bit of extra head height to get the air out of the rear bleed point once I'd filled the cooling system.
I waited for it to cool off again tonight, then topped up the rear bleed point and got a bit more air out (put about 250ml more water in).
I'll check again tomorrow morning, but I think it will be ok.
Lol, err, maybe it is then...
Still no pinging either. ;)
Edited by Daleo
Sometimes a pain, sometimes not was what I was getting at. I bled mine for a good 20 mins or so, using exactly that method you described Dale. Parked it up, the next couple of times the car was allowed to fully cool off, the bugger drank all the overflow tank. So, I cracked it again and worked on it some more, and its good now.
Never gets hot - plus I have the fans set to 88 :)
Yeah spot on, mine was all good this morning, and I'll check it again tonight.
Mine is now steady at around 86 deg, when going slow or stopped; it might get to 89. Big difference to 88-94 deg running and a max of 104.
We'll see what it's like when we get some hot weather, but the core was more than twice as thick, so it should be fine.
I got the white whale started today, the timing chain rattled like crazy for at least 5 minutes until the tensioners pumped up. All good, no leaks and the coolant stopped bubbling after a short while. (unlike before. lol.)
Here are some pics of the coolers, both sides have thermo fans behind them, a 14 inch for the 12an oil cooler and a 9 inch for the trans cooler. I also have a controller to switch them both on at whatever oil temp I decide to set it to.
I scored this wood heater for the shed too, it makes this Melbourne winter bearable now in the man cave. :)
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
