Got rid of the old paper job and dropped in a K&N filter yesterday. I'm probably imagining it but it feels a little bit more responsive on the pedal. :woot:
Nah, I reckon they make a noticeable difference too.
Finally got some time to fit the greddy oil cooler to the car.....only problem is I am having to move the power steering cooler! :(
Other than needing new tyres and a power steering cooler......also the new rear wing the car is safe to go to the track finally.
I thought Scotty had said his oil cooler makes no real difference?
Oh, and to my Stagea, this weekend I finally got the wideband bung welded in, so just need to wire it up now. Also getting closer to sorting the Fcon out, looking to change some of the wiring around to run the HKS sensors instead of the stockers.
I thought Scotty had said his oil cooler makes no real difference?.
No real difference to performance that is correct!....however the temps generated at full song on a track are a little different....every bit helps. Even if I only do 3 lap sprints "at my pace" on short tracks and it keeps the temps down it will be great. My only stuff up today was that I didn't put the sensor in the sandwich play before filling the oil.
Edited by Jetwreck
Definitely need the oil cooler for the track, as well as a huge trans cooler and the power steering. Not much room left in the front of mine now. With a massive 30 row oil cooler that has a 14 inch thermo mounted to it, my oil still got to 110 degrees at PI, the water hovered around 91 with the stock radiator.
My car let me down today. :( The throttle became unresponsive and I had to crawl home at 20-30kph. (after pulling the throttle plug for some more revs.) I suspected Leon's cruse at first so I disconnected it, no change. Swapped the throttle pedal over, still the same. I even pulled the ecu plug and checked the loom, no problems. It turned out to be the throttle body itself which is unusual, I haven't heard of one failing before. At least I have a few laying around I guess. The best part is it idles on 700 again instead of 1000 revs. Win.
I think the tps shat itself, it read 2.5v continuously at idle. I guess it was in limp mode but I didn't have to reset anything once the new throttle was in... I had a similar experience at PI, had to pit as the car wouldn't rev. It ran fine again once I restarted the car.
Dropped the oil yesterday - well, I started on Sat - but after putting the oil flush in I couldn't find the extra 2L of 300v...and shops were closed..so had to finish it off on Sunday.
Anyway, its good to be driving again.... :banana:
Unless you want to be looking at a constant CEL and an unhappy ECU, I'd be leaving the stock sensors in as well as running the Fcon sensors.
I mentioned that, but apparently you can set it up so the F-con only reads the input from the sensors as they're fed into the stock ECU.
Can't run both apparently.
Which sensors?
I run both, I just cut the wire at the fcon end and can swap between them with bullet connectors. The stock ecu still gets the stock sensor signal as the patch loom goes straight through.
Cam, what were my errors again? I am keen to get rid of them all now. I remember the stock o2 was missing...
I didn't unplug any OEM sensors when I ran the Fcon as I didn't want the damn CEL on all the time.
I'm sure the Fcon can be set up to read the HKS IAT and MAP sensors and ignoring the ECU's feedback for these.
Buggered if I know. Like there is a chance I'm remembering the one that couldn't be removed - let alone the one that were removed!
I'm glad i'm not the only one with a failing memory. :P
I don't know how it works. The guys are modifying the harness to take the HKS sensors and have looked at the VQ25DET ECU pin out to get it all working. I'll see how it goes when it's on.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
