I like your style. I want to fit an oil pressure/temp gauge somewhere, might try and move the DVD ROM, but I'm keeping the factory screen.
Picked the car up from AM Performance tonight. Andrew had pulled off the intake and traced the flange, so while he gets the flanges laser cut I get the car back so I can change the belts and do some other bits.
Was good to get it back and go for a proper drive, when I wasn't in as big a hurry as when I drove it there. Only the second time I'd driven it since the EVC6 went in.
Obviously there are still a few things to sort out with the EVC.
Firstly, I noticed the settings had zeroed out. I reset it all, and then noticed that every time the ignition is switched off it wipes the settings. I'll download the PowerWriter software too, and see if I can work out a decent solution.
Second, once setup for 15PSI peak/optimum boost, I notice it now makes 1PSI at ~1500rpm according to the EVC display. Boost feels like it comes on a lot stronger, and it feels much nicer to drive, especially higher in the rev range.
Thirdly, since I run a pod and the Turbosmart dual port blow off valve (plumbed back and adjusted properly), I've had some chirping and turbo noise which is apparently not a good thing. I spoke to Turbosmart and they blamed it on the pod, not the spring or anything else setup wise. I notice since the EVC went in this is virtually eliminated.
So all in all, very happy with the HKS EVC6, and once it's setup properly should be an awesome addition. Car certainly feels sluggish on the default 11PSI though!
I considered moving the DVD rom first up, but the cables to the back of it were so short, the only place you could really tuck it away is right where the passenger airbag sits. There's just no room under the dash without taking something else out & I wouldn't like the thought of cutting & extending the leads to somewhere else either, they look like they'd be pretty easy to screw up.
I want too concerned about losing the factory screen capabilities (mine was even converted to English when I got it) - mainly because I had already lined up the Alpine 2din
Your android tablet gauge pod is awesome.
Clean, no clutter, no tackyness... just smooth...
C34s wouldnt have a compliant OBD for that kind of multimonitor thingswoud they?
I had a look at a few ebay head up displays but wasnt certain if it would work and be configurable enough to give me:
A) RPM graph
B) dig speed
C) dig boost
Thats it, no other shit on my windscreen.
dig water temp would be nice.
Edited by shane344
A) RPM graph
B) dig speed
C) dig boost
The info is all interpreted through the OBD port by the HKS OB-Link, which is plugged into the car & sends the info to the android tablet (or phone) which is read & displayed by the corresponding app.
HKS have a list of compatible vehicles that the OB-Link works on, not sure if the C34 is on there or not...
The OB-Link cost me about $230 from Greenline
Took Moby for a drive, and filled up the tank.
Got the EVC setup. I really should learn to read instructions and push the combination to write the settings to the ROM.
It's now setup for normal boost at 15PSI and max boost at 15.5PSI. I don't want to go any higher than that on the stock turbo, lest it blow apart.
It feels brilliant from 1500rpm now, really pulls and goes, which makes the throttle restriction worse... Good thing it'll be leaving soon! :D
The turbo is making far fewer weird noises now, less 'helicopter' noises, less sneezing. It feels like it's either on, or off, with no slur in between.
I like it!
Found a standard 260RS front bar. It's months away from getting to me but i'll respraying the front end and touching up the rest of the car when it finaly get here.
Anyone keen on a genuine Freeway Dolphin front bar?
Pretty Sure its only the 35's that have this OBD2 port. 34's use the older OBD1.
Also did this to my stagea yesterday
drove over a roofing screw :verymad:
Edited by Nadnerb
Replaced the accessories and air con belts with new Gates Micro V belts according to Cam's helpful tutorial: http://m35stagea.info/forum/viewtopic.php?f=6&t=88&p=1867&hilit=belt#p1867
Used the same part numbers as Andy. Was pretty easy.
There is some squealing on startup now which goes away very quickly. I think the bracket for the tensioner on the aircon belt is cactus though, looks bent, so may need to replace this depending on how it goes.
Also thought it was interesting that Gates' instructions recommend replacing the tensioners with the belt - has anyone ever done this?
Also didn't bother putting the undertray back on. Looks pretty sad and sorry for itself. Think we need to look into getting something like this made locally:
Is this something AM Performance could knock up?
Possibly, otherwise I know dad used a local sheet metal mob to do some work on his rally car, might be worth chasing down.
For it to be worth making locally it'd need to be less than $200 each, since you can get them for ~US$170 plus shipping.
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
